RADIATOR
1 19010RYEA52 RADIATOR (DENSO)
2 19011PH1621 BOLT, DRAIN (DENSO)
3 19012671300 GASKET, DRAIN (DENSO)
4 19014PGKA01 SEAL (LOWER)
5 19015RYEA01 SHROUD
6 19020RN0A71 FAN, COOLING
7 19030RYEA11 MOTOR, COOLING FAN
8 19045RAA003 CAP, RADIATOR (DENSO)
10 19046RAAA00 LABEL, RADIATOR CAP
11 19047PLC003 COVER, RADIATOR CAP (DENSO)
12 32175PDAE01 CLIP, HARNESS
13 37870RTA005 SENSOR ASSY., WATER TEMPERATURE (DENSO)
14 37873RYEA10 SUB-WIRE, TW SENSOR
15 38611RYEA01 FAN, COOLING
16 38615RYEA01 SUB SHROUD
17 38616RYEA11 MOTOR, COOLING FAN
18 38619RJEA01 COVER, FAN MOTOR
19 90051P5A004 SCREW-WASHER (4X11)
20 90042PAAA01 BOLT-WASHER (6X16) (DENSO)
21 90043PD2003 NUT, HEX. (5MM) (DENSO)
22 91307RTA005 O-RING (DENSO)
23 91507P01003 CLIP B, HARNESS BAND (129.4MM)(DARK BROWN)
24 91558P8CA01 CLIP, HARNESS BAND (150MM) (VIOLET)
