24 COMBINATION SWITCH
1 06350STKA21 CYLINDER SET, KEY
2 06351STKA11 CYLINDER SET, KEY
3 35102SV4003 BOLT, BREAK HEAD
4 35103S04003 SCREW, RECESSED
5 35108S30003 HOLDER, COLUMN
6 35111STX325 KEY, IMMOBILIZER & TRANSMITTER(BLANK) (MEMORY DRIVER 1)
6 35111STX327 KEY, IMMOBILIZER & TRANSMITTER(BLANK) (MEMORY DRIVER 2)
7 35111SNR306 KEY, IMMOBILIZER (MAIN)(BLANK)(BLACK)
7 35112SNR305 KEY, BLANK (IMMOBILIZER)(SUB)(GRAY)
8 35117STKA11 SCREW, FLAT
9 35119STX315 CASE, KEY (DRIVER 1) (BLANK) (MEMORY DRIVER 1)
9 35119STX316 CASE, KEY (DRIVER 2) (BLANK) (MEMORY DRIVER 2)
10 35130SJAA01 SWITCH, STEERING
11 35251STKA01 BODY, SWITCH
12 35255STKA11 SWITCH ASSY., LIGHTING & TURN
13 35256STKA02 SWITCH ASSY., WIPER
14 35400S5A013 SWITCH ASSY., DOOR (MATSUSHITA)
15 39730SNAA02 IMMOBILIZER & KEYLESS UNIT
16 72118ST7003 SCREW, TAPPING (3X5)
17 72147STXA02 MODULE ASSY., KEYLESS (MEMORY DRIVER 1)
17 72147STXA22 MODULE ASSY., KEYLESS (MEMORY DRIVER 2)
18 72148S0A000 BATTERY (CR1616) (MSDS)
19 90132S9VA01 SCREW, ET (5X18)
20 938930501408 SCREW-WASHER (5X14)
21 9390122520 SCREW, TAPPING (3X20)
22 35118STKA01 COVER, MODULE
