06 FUEL TANK
1 17044STKA03 TANK SET, FUEL
2 17045STKA01 MODULE ASSY., FUEL PUMP
3 17046STKA00 NUT & GASKET SET, FUEL LOCK
4 17047STKA00 METER
5 17048STKA00 FILTER SET, FUEL
6 17049STKA00 SUB-PUMP ASSY., FUEL
7 17050STKA00 TUBE SET, TRANSFER
8 17051STKA00 SUB METER
9 17517STKA00 PIPE, R. FUEL TANK GUARD
10 17518STKA00 PIPE, L. FUEL TANK GUARD
11 17519STKA00 PROTECTOR, FUEL TANK
12 17521STKA00 BAND, R. FUEL TANK MOUNTING
13 17522STKA00 BAND, L. FUEL TANK MOUNTING
14 17525SM4000 BOLT-WASHER (10X35)
15 17651STKA01 TUBE, FILLER NECK
16 17652SDAA31 CLIP, FILLER TUBE
17 17652SDA003 CLIP, FILLER TUBE (28.6MM)
18 17660STKA02 PIPE, FUEL FILLER
19 17668STKA00 COVER, FUEL FILLER PIPE
20 17670TR0A11 CAP ASSY., FUEL FILLER
21 17711SDCL01 RETAINER (NATURAL) (TOKAI)
22 74660STKA00 CAP ASSY., FUEL MAINTENANCE HOLE
23 90150S04003 BOLT, GROUND (6X16)
24 90361S3VA00 NUT, CAP (6MM)
25 90671SB2003 BOLT, FR. FENDER
26 91501S04003 CLIP, FENDER (INNER)
27 91594SNAA01 CLIP, FILLER CAP
28 91601SH3013 GROMMET, SCREW (5MM) (BLACK)
29 934070802004 BOLT-WASHER (8X20)
30 9390125220 SCREW, TAPPING (5X12)
