02 INSTALL PIPE - TUBING
1 16725PNA003 CLAMP A, FUEL HOSE
2 17400RWCA00 PIPE A, INSTALL
3 19442RWCA00 HOSE, BREATHER OUTLET
4 19508RWCA00 HOSE, THROTTLE BODY IN.
5 19509P72003 CLAMP, ELECTRONIC AIR CONTROL VALVE HOSE
6 19540RWCA00 PIPE, INSTALL
7 36145RWCA01 VALVE, CHECK
8 36162RWCA01 VALVE, PURGE CONTROL SOLENOID
9 36163RWCA00 STAY, PCS
10 36166RJAA01 JOINT, PURGE
11 36167RWCA00 TUBE A, PURGE
12 36168RWCA00 TUBE B, PURGE
13 36169RWCA00 TUBE C, PURGE
14 36170RWCA00 TUBE D, PURGE
15 36171RWCA00 TUBE E, PURGE
16 36173RWCA00 TUBE G, PURGE
17 46408STKA00 TUBE A, MASTER POWER
18 53729671003 CLAMP D (15.5MM)
19 91406SAAJ00 CLAMP, TUBE (D12)
20 91406SAA000 CLAMP, TUBE (D12)
21 91407RWCA00 CLAMP, TUBE (D12.5)
22 91408SDB000 CLAMP, TUBE (D13.0)
23 91412SDCL01 CLAMP, FUEL TUBE (D15.5)
24 91597S5A931 CLIP, DRAIN TUBE
25 934010601205 BOLT-WASHER (6X12)
26 938920502008 SCREW-WASHER (5X20)
27 950024073004 CLAMP, TUBE (D7.3)
28 950053500810M BULK HOSE, VACUUM (3.5X8000) OEM CUT SIZE: (3.5X135)
28 950053500810M BULK HOSE, VACUUM (3.5X8000) OEM CUT SIZE: (3.5X95)
29 957010601208 BOLT, FLANGE (6X12)
