Топливопровод
Топливопровод
1 16720RYEA01 HOSE, FUEL FEED
2 16725RAC003 CLAMP, FUEL HOSE (NATURAL)
3 16726PWA004 COVER B, FUEL CONNECTOR (BLACK)
4 16727RKB003 COVER, FUEL CONNECTOR
5 16731PVJA00 STAY, FUEL HOSE
6 17011SHJA01 CANISTER ASSY.
7 17259PE0661 COLLAR, MOUNTING
8 17260PE0670 RUBBER, MOUNTING
9 17315SHJA01 FILTER, CANISTER
10 17321SDAA01 Кронштейн
11 17330S9VA01 FILTER, DUST
12 17355S9VA01 JOINT, PRESSURE SENSOR
13 17356STXA00 BRACKET, DRAIN JOINT
14 17357STXA00 BRACKET, CANISTER FILTER
15 17357S9VA01 JOINT, DRAIN TUBE
16 17358STXA00 BRACKET, CANISTER
17 17359SDAA01 BOLT, CANISTER MOUNTING (8MM)
19 17373STXA00 TUBE A, CANISTER DRAIN
20 17374STXA00 TUBE B, CANISTER DRAIN
21 17375STXA00 TUBE C, CANISTER DRAIN
22 17376STXA00 TUBE D, CANISTER DRAIN
23 17377STXA00 TUBE E, CANISTER DRAIN
24 17378STXA00 TUBE F, CANISTER DRAIN
25 17385STXA00 TUBE ASSY. A, ATMOSPHERIC
26 17386STXA00 TUBE B, ATMOSPHERIC
27 17578STXA00 COVER, DRAIN PIPE
28 17700STXA01 PIPE, FUEL FEED
29 17707STXA01 TUBE, FUEL FEED
30 17711STXA01 RETAINER (GRAY)
31 17711STXA11 RETAINER (BLUE)
32 17711STXA31 RETAINER (NATURAL)
33 17711S0X931 Уплотнитель
34 17717STXA01 HOSE ASSY., FUEL PURGE
35 17719STXA01 PIPE, ATMOSPHERIC
36 17720STXA01 PIPE, FUEL PURGE
38 17724STXA01 TUBE, FUEL PURGE
39 17741STXA01 PIPE A, CANISTER DRAIN
40 17742STXA01 PIPE B, CANISTER DRAIN
41 17743STXA01 PIPE C, CANISTER DRAIN
42 17743S9VA11 JOINT, THREE WAY
43 17761STXA00 STAY A, FUEL PIPE
44 17762STXA00 STAY B, FUEL PIPE
45 17763STXA00 STAY C, FUEL PIPE
46 17764STXA00 STAY D, FUEL PIPE
47 17765STXA01 STAY E, FUEL PIPE
48 37940SNAA01 SENSOR, VENT PRESSURE
49 46391SDAA01 CLIP G, BRAKE PIPE
50 75353671000 LOCK, SCREW
51 90001P7J000 BOLT, SPECIAL (6X25)
52 90361SV4003 NUT, PAINT CUTTING (6MM)
53 91391SDAA01 O-RING
54 91394SDAA01 O-RING
56 91591SHJA01 CLAMP A, FUEL PIPE
57 91591S9VA01 CLAMP A, FUEL PIPE
58 91594SJCA00 RUBBER A, FUEL PIPE INSULATOR
59 91594S3VA51 CLAMP D, FUEL PIPE
60 91597SJCA01 CLAMP C, FUEL PIPE
61 91597STXA01 CLAMP A, FUEL PIPE
62 91598STXA01 CLAMP B, FUEL PIPE
64 934050601604 Болт (6X16)
65 934050601608 Болт (6X16)
67 9405008040 NUT, FLANGE (8MM)
    41.7 KB · Просмотры: 159
