Сцепление (LOW)
Сцепление (LOW)
1 22510RJB003 GUIDE, LOW CLUTCH
2 22520RJB003 PISTON, LOW CLUTCH
3 22533P7W003 SEAT, RETURN SPRING
4 22537P0Z003 SPRING, CLUTCH DISK
5 22539RDK013 SPRING, CLUTCH DISK
6 22542P7W003 SPRING, CLUTCH RETURN
7 22543RJF003 PLATE, CLUTCH WAVE (1.6MM)
8 22544RJB003 DISK, CLUTCH
9 22546RJBE01 DISK, CLUTCH
10 22554RDK003 PLATE, CLUTCH END (4) (3.4MM)
10 22555RDK003 PLATE, CLUTCH END (5) (3.5MM)
10 22556RDK003 PLATE, CLUTCH END (6) (3.6MM)
10 22557RDK003 PLATE, CLUTCH END (7) (3.7MM)
10 22551RDK003 PLATE, CLUTCH END (1) (3.1MM)
10 22558RDK003 PLATE, CLUTCH END (8) (3.8MM)
10 22552RDK003 PLATE, CLUTCH END (2) (3.2MM)
10 22559RDK003 PLATE, CLUTCH END (9) (3.9MM)
10 22553RDK003 PLATE, CLUTCH END (3) (3.3MM)
11 22570RJB003 PISTON, CLUTCH (L-H)
12 22673PVL003 PLATE, CLUTCH WAVE (L-H)
13 22673P7W003 PLATE, CLUTCH (L-H)
14 22675RDK003 PLATE B, LOW-HOLD CLUTCH
15 90603P0Z000 CIRCLIP, OUTER (44MM)
16 90605P0Z000 RING, SNAP (141MM)
17 91302P0Z003 O-RING (44.1X2.2) (NOK)
18 91303PF4004 O-RING (110X2.2) (NOK)
19 91303PY4004 O-RING (119.1X2.3) (NOK)
20 91303P0Z003 O-RING (45.1X2.2) (NOK)
21 91304P0Z003 O-RING (52.1X2.2) (NOK)
    35.1 KB · Просмотры: 227
