Облицовка передней двери
AcuraINFO
21 Янв 2016
Дмитрий
Аcura
1 32758-TZ3-A00 Subcord,DR Door 1
2 32759-TZ3-A00 Subcord,As Door 1
Replaced by: 32759-TZ3-A01
2 32759-TZ3-A01 Subcord,As Door 1
3 34253-SNA-003 Bulb, Wedge (12V 3.4W) 2
4 34257-SNB-003 Lens 2
5 35190-TX4-A01 Switch Assy., Remote Control Mirror 1
6 35750-TZ3-A01 SW ASSY,P/W MASTE 1
7 35760-TZ3-A01 SW ASSY,P/W AS 1
8 35930-TZ3-A01 Ind Assy,Bsi(R) 1
9 35961-TZ5-A01 SWITCH, SEAT MEMORY 1
10 35980-TZ3-A01 Ind Assy,Bsi(L) 1
11 38850-TZ3-A01 UNIT ASSY,MEMORY 1
12 72335-TZ3-A01 Wthstp,R FR Door 1
13 72375-TZ3-A01 Wthstp,L FR Door 1
15 72442-TZ3-A11ZA Garn,R Fr*NH690L* 1
Interior color: A-PREMIUM BLACK,B-LIGHT JEWEL GRAY,C-SANDSTORM,D-BRUIN
17 72482-TZ3-A11ZA Garn,L FR*NH690L* 1
18 83501-TZ3-A01ZA BASE ASSY*YR464L* 1
Interior color: D-BRUIN
18 83501-TZ3-A01ZB BASE ASSY*YR436L* 1
Interior color: C-SANDSTORM
18 83501-TZ3-A01ZC BASE ASSY*NH802L* 1
Interior color: B-LIGHT JEWEL GRAY
18 83501-TZ3-A01ZD BASE ASSY*NH690L* 1
19 83502-TZ3-A01ZA ARMREST A*YR464L* 1
19 83502-TZ3-A01ZB ARMREST A*YR436L* 1
19 83502-TZ3-A01ZC ARMREST A*NH802L* 1
19 83502-TZ3-A01ZD ARMREST A*NH690L* 1
20 83504-TZ3-A01ZD COVER,R P*NH690L* 1
21 83505-TZ3-A01ZD BASE,R SW*NH690L* 1
22 83506-TZ3-A01ZD CASE,R IN*NH690L* 1
23 83508-SDA-000ZZ Bracket, Pull Pocket 2
24 83510-T1G-E11 LIGHT ASSY., ACCESSORY 2
25 83510-TZ3-A01ZA CAP,R INN*NH690L* 1
26 83551-TZ3-A01ZA BASE ASSY*YR464L* 1
26 83551-TZ3-A01ZB BASE ASSY*YR436L* 1
26 83551-TZ3-A01ZC BASE ASSY*NH802L* 1
26 83551-TZ3-A01ZD BASE ASSY*NH690L* 1
27 83552-TZ3-A01ZA ARMREST A*YR464L* 1
27 83552-TZ3-A01ZB ARMREST A*YR436L* 1
27 83552-TZ3-A01ZC ARMREST A*NH802L* 1
27 83552-TZ3-A01ZD ARMREST A*NH690L* 1
28 83554-TZ3-A01ZD COVER,L P*NH690L* 1
29 83555-TZ3-A01ZD BASE,L SW*NH690L* 1
30 83556-TZ3-A01ZD CASE,L IN*NH690L* 1
31 83560-TZ3-A01ZA CAP,L INN*NH690L* 1
32 90132-SS0-000 Screw, Tapping (4X10) (Po) AR
33 90137-SH3-000 Screw, Tapping (4X16) 2
34 90662-SB2-003 Grommet, Screw (5MM) 4
35 90666-SDA-A01 Clip, Snap Fitting (Po)(Natural) 8
36 91506-STX-A01 Clip, Harness Band (148MM) (Black) 7
37 91531-T4N-003 CLIP, WIRE HARNESS (44MM) (BLACK) 2
38 91534-SWA-003 Clip, Connector (Dark Gray) 2
39 91540-TA0-003 Clip, Harness Band (100.1MM) (Natural) 2
40 91542-SNA-003 Clip, Harness Band (164.5MM) (Dark Blue) 2
41 91560-SZW-003 Clip, Door Lining (Apple Green) 18
42 91661-SEP-A00 Clip A, Sash Garnish (Inner) 2
43 91662-SEP-A00 Clip B, Sash Garnish (Inner) 2
44 93901-22220 Screw, Tapping (3X10) 12
45 93903-14120 Screw, Tapping (4X8) 4
46 93903-45320 Screw, Tapping (5X16) 4
47 83503-TZ3-A01ZA PANEL ASSY., R. FR. DOOR TRIM *NH764X* (SATIN CHROME PLATING) 1
48 83553-TZ3-A01ZA PANEL ASSY., L. FR. DOOR TRIM *NH764X* (SATIN CHROME PLATING) 1
    18.5 KB · Просмотры: 208
