Крепления жгутов электропроводки
1 32110STXA01 PROTECTOR, SIDE SILL
2 32112S2K003 BAND, CABLE
3 32120P5LA01 HOLDER, CORRUGATED (25MM) (DARK GREEN)
4 32132SM4003 BAND, WIRE HARNESS OFFSET (20)(122.5MM) (BLACK)
5 32132S6A003 BAND, WIRE HARNESS OFFSET (20)(122.5MM) (DARK GREEN)
6 32133SM4003 BAND, HARNESS OFFSET (30) (122.5MM) (YELLOW)
7 32134SM4003 BAND, HARNESS OFFSET (10) (122.5MM) (BROWN)
8 32146SH3003 CONNECTOR, DIODE (2P)
9 32151STXA00 BRACKET, STEERING LOCK
10 32152STXA00 BRACKET (OBD-2)
12 32164STXA01 LID, INTERIOR WIRE PROTECTOR
13 32602STXA00 BRACKET, TRANSMISSION GROUND CABLE
14 32611SJCA10 BRACKET, SUB-GROUND
15 48322RYG000 STAY B, RR. DIFFERENTIAL CABLE
16 48323RYG000 STAY C, RR. DIFFERENTIAL CABLE
17 38564SA7013 GROMMET, WASHER TUBE (MITSUBA)
18 90627SA5003 CLIP, WIRE HARNESS (50MM) (BLUE)(HARNESS TAPING)
20 91476SD4003 CLIP, OFFSET (21) (60MM) (BROWN)
21 91506P01003 CLIP A, HARNESS BAND (129.4MM)(DARK GRAY)
22 91506RTA003 CLIP A, HARNESS BAND (129.4MM)(DARK VIOLET)
23 91506STXA01 CLIP, HARNESS BAND (148MM) (BLACK)
24 91507P01003 CLIP B, HARNESS BAND (129.4MM)(DARK BROWN)
25 91507SNA003 CLIP, HARNESS BAND (164.5MM) (BROWN)
26 91507693003 CLIP, WIRE HARNESS (50MM) (BLACK)(HARNESS TAPING)
27 91508STXA00 CLIP, HARNESS BAND (148MM) (BLACK)
28 91531SDA003 CLIP, HARNESS BAND (145MM) (NATURAL)
29 91531SR3003 HOLDER, CONNECTOR (128.6MM) (NATURAL)
30 91531S04003 CLIP, WIRE HARNESS (44MM) (NATURAL)
31 91533SDA003 CLIP, CONNECTOR (BEIGE)
33 91533S04003 CLIP, CONNECTOR (NATURAL)
34 91533S82003 CLIP, CONNECTOR (BLACK)
36 91540S0A003 CLIP, HARNESS BAND (96.9MM) (NATURAL)
37 91540S30003 CLIP, HARNESS BAND (151.5MM) (NATURAL)
38 91540S7S003 CLIP, HARNESS BAND (157.7MM) (BLACK)
39 91541S0A003 CLIP, HARNESS BAND (145MM) (BLACK)
40 91542SNA003 CLIP, HARNESS BAND (164.5MM) (DARK BLUE)
41 91545SNA003 CLIP, HARNESS BAND (164.5MM) (W/SEAL)(DARK BLUE)
42 91545SV4003 CLIP, HARNESS BAND (145.2MM) (NATURAL)(W/SEAL)
43 91545S2A003 CLIP, HARNESS BAND (151MM) (BROWN)(W/SEAL)
44 91547SH3003 CLIP, BAND (160MM) (NATURAL)
45 91548SV4003 CLIP, BAND (6MM BOSS) (127MM) (NATURAL)
46 91548S84003 CLIP, HARNESS BAND (128MM) (GRAY)
48 91554SM4003 HOLDER, BRACKET (RED)
49 91555SM4003 CLIP, CONNECTOR (RED)
50 91555S3VA01 HOLDER, CONNECTOR
51 91557S82003 CLIP, WIRE HARNESS (EDGE)
52 91558SJ6003 STRAP, HARNESS (30) (107.5MM) (BLACK)
54 91559ST5003 CLIP, HARNESS BAND OFFSET (30)(NATURAL)
55 91559S47003 CLIP, HARNESS BAND (167MM) (NATURAL)
56 91565SEL003 CLIP, CONNECTOR (BLACK)
57 91565S0X003 CLIP, CONNECTOR (DARK GREEN)
58 91572SM4003 CLIP, WIRE HARNESS
59 91577STXA01 CLIP, WIRE HARNESS (122.5MM) (OFFSET)(SEAL)(BLUE)
60 91902SB2003 CUSHION, WIRE HARNESS (50X100)
61 91902STXA01 PLASTER, WIRE HARNESS (50X100)
62 934050602008 Болт
63 9390334380 SCREW, TAPPING (4X12)
64 957010601208 Болт 6X12
65 957011002008 Болт 10X20
66 30510SNAA01 CONDENSER (0.47 MICRO F)
66 30510SCC013 CONDENSER
67 91559S5A003 HOLDER, HARNESS (BLACK)
69 91705RYEA01 COVER, ENGINE CONTROL MODULE CONNECTOR
    44.4 KB · Просмотры: 168
