Водяной клапан
Водяной клапан
1 79117S3VA00 Патрубок
2 79118S3VA01 Патрубок
3 79323S0XA01 BRACKET A, HEATER PIPE
4 79324S0XA01 BRACKET B, HEATER PIPE
5 79325S0XA11 BRACKET D, HEATER PIPE
6 79326S0XA11 BRACKET E, HEATER PIPE
7 79327S0XA01 BRACKET F, HEATER PIPE
8 79328S0XA01 BRACKET G, HEATER PIPE
9 79329S3VA01 BRACKET G, HEATER PIPE
10 79331S3VA01 PIPE ASSY.
11 79332S3VA01 PIPE ASSY.
12 79710S0XA01 VALVE ASSY., WATER
13 79721S3VA00 HOSE A1, WATER INLET
14 79722S0XA00 HOSE A2, WATER INLET
15 79723S0XA00 HOSE B, WATER INLET
16 79725S0XA00 HOSE A, WATER OUTLET
17 79726S3VA00 HOSE B, WATER OUTLET
18 79731S0XA00 GROMMET, HEATER PIPE
19 79760SE0000 GROMMET, HEATER PIPE
20 90129S0XA01 NUT
21 90361SV4003 NUT, PAINT CUTTING (6MM)
22 90661SL5003 CLIP, WATER HOSE
23 19513PE0003 CLAMP, WATER HOSE (21.7MM) (CHUO HATSUJO)
24 91901S0XA00 SCREW, PAN (4X8)
25 92301050160H BOLT, RECESSED (5X16)
26 934030601604 Болт (6X16)
27 9410105400 Шайба, 5MM
28 9411105400 WASHER, SPRING (5MM)
29 91557S87A01 CLAMP, HEATER
    33.3 KB · Просмотры: 214
