SELECT LEVER
1 35740SZNA82 HARNESS ASSY.
2 39550TA0A01 SOLENOID, SHIFT LOCK
3 54023SYA981 STOPPER SET, SHIFT LOCK
4 54030TK4A81 RELEASE, SHIFT LOCK
5 54031STKA81 SPRING, RELEASE
6 54110SYA981 STOPPER, SHIFT LOCK
7 54130SZNA81ZA KNOB ASSY., SELECT LEVER NH773L: LIGHTER PREMIUM BLACK THREAD
7 54130SZNA81ZB KNOB ASSY., SELECT LEVER NH774L: DARKER NIGHTFALL AMETHYST THREAD
7 54130SZNA81ZC KNOB ASSY., SELECT LEVER YR408L: DARKER UMBER THREAD
8 54133TL0G82ZA RING, PUSH KNOB NH167L: GRAPHITE BLACK
9 54200SZNA82 BRACKET SET, SELECT LEVER
10 54201SZNA81 BRACKET, SELECT LEVER
11 54300SZNA81ZA BOOT SET, SELECT NH167L: GRAPHITE BLACK
12 54315SZNA81 WIRE, CONTROL
13 54714SZNA81ZA LID, ESCUTCHEON NH526L: SATIN SILVER
14 54721SZNA82ZA ESCUTCHEON SET, SELECT LEVER NH526L: SATIN SILVER
15 54722S9A981 STRAP, CABLE
16 54903SYA981 SCREW, FLAT (5X8)
17 90112SZNA00 BOLT-WASHER (8X25)
18 90126SYA981 SCREW-WASHER (3X12)
19 90351SB2003 NUT, FLANGE (8MM)
20 90361SV4003 NUT, PAINT CUTTING (6MM)
21 91565S0X003 CLIP, CONNECTOR (DARK GREEN)
22 934010601608 BOLT-WASHER (6X16)
23 934010802008 BOLT-WASHER (8X20)
24 9405006080 NUT, FLANGE (6MM)
