SELECT LEVER
1 35500STXA02ZA SWITCH ASSY., ACTIVE DAMPER NH167L: GRAPHITE BLACK
2 35854STXA21 BULB A, A (14V 80MA)
3 35855STXA11 BULB B, B (14V 80MA)
4 54023SEA981 STOPPER, SHIFT LOCK
5 54030STXA83 RELEASE, SHIFT LOCK
6 54032SEA981 CUSHION, SHIFT LOCK
8 54070SDCA81 BULB (14V 1.4W)
11 54206SEAG81 CLIP, CABLE
14 54710STXA94ZC ESCUTCHEON SET, CONSOLE NH572L: DARK SILVER
15 54716STXA82ZB LID, ESCUTCHEON NH572L: DARK SILVER
17 90351SB2003 NUT, FLANGE (8MM)
18 91640SM4003 GROMMET, SCREW (4MM)
19 934050803008 BOLT-WASHER (8X30)
20 54903SYA981 SCREW, FLAT (5X8)
21 9405006080 NUT, FLANGE (6MM)
22 39550TA0A01 SOLENOID, SHIFT LOCK
23 54131STXA83ZD KNOB SET, SELECT LEVER NH690L: PREMIUM BLACK
23 54131STXA83ZK KNOB SET, SELECT LEVER (TYPEK) (NA USE ALT: 54131-STX-A83ZC)
24 54200STXA84 BRACKET SET, BASE
25 54300STXA84ZD BOOT SET, SELECT NH690L: PREMIUM BLACK
25 54300STXA84ZK BOOT SET, SELECT (TYPEK) (NA USE ALT: 54300-STX-A84ZC)
26 54315STXA84 WIRE, CONTROL
27 90361SV4003 NUT, PAINT CUTTING (6MM)
