REAR LOWER ARM
1 42514SZH003 CLAMP, WIRE
2 42522SNA003 CLAMP, WIRE (BLUE)
3 42524SLJ003 CLIP, CONNECTOR (BLACK)
4 52210TX5A00 KNUCKLE, R. RR.
5 52215TX5A00 KNUCKLE, L. RR.
6 52300TX4305 SPRING, RR. STABILIZER
7 52308SZ3000 HOLDER, STABILIZER BUSH
8 52315STKA01 BUSH, RR. STABILIZER HOLDER
9 52320STKA01 LINK, RR. STABILIZER
11 52345TX4A00 ARM A, RR. (LOWER)
12 52355STKA01 ARM B, R. RR. (LOWER)
13 52360STKA01 ARM B, L. RR. (LOWER)
14 52364SDAA00 WASHER, CONTROL ARM
15 52371STKA00 ARM, R. RR. TRAILING
16 52372STKA00 ARM, L. RR. TRAILING
17 52387TX4A00 BOLT, ARM B ADJUSTING (LOWER)
18 52388TX4A01 PLATE, CAM
19 52390STKA01 ARM, R. RR. (UPPER)
20 52400STKA01 ARM, L. RR. (UPPER)
21 52454S84A01 BOOT, DUST (UPPER)
22 57470TX5A01 SENSOR ASSY., R. RR.
23 57475TX5A01 SENSOR ASSY., L. RR.
24 90002S10000 NUT, FLANGE (10MM)
25 90100SHJA00 BOLT, FLANGE (6X16.5)
26 90162SR3000 BOLT, FLANGE (14X60)
27 90170STKA02 BOLT, ARM (LOWER)
28 90172SP0000 BOLT B, SHOCK ABSORBER BRACKET
29 90174SP0003 BOLT, SHOCK ABSORBER LOCK (12X88)
30 90174SZ3000 BOLT, FLANGE (10X20)
31 90215SEAE10 NUT, SELF-LOCK (12MM)
32 90215SHJA00 NUT, SELF-LOCK (12MM) (CLINCH)
33 90212SA5003 NUT, SELF-LOCK (10MM)
34 90362SJA000 NUT, SELF-LOCK (12MM) (NYLON)
35 90365SJA000 NUT, CASTLE (12MM)
36 90651TX4A00 WASHER, RR. KNUCKLE
37 90701SX0003 CLIP, ARM (UPPER)
38 91507STKA01 CLIP, HARNESS BAND (96.9MM) (NATURAL)
