REAR BRAKE
1 01473SZ3A00 CALIPER SET, RR.
2 42200T0A951 BEARING ASSY., RR. HUB UNIT (NTN)
3 42510TX4A01 DISK, RR. BRAKE DRUM (INNER)
4 42511SP0000 CAP, MAINTENANCE HOLE
5 43018T0GA01 CALIPER SUB-ASSY., R. RR. (MSDS)
6 43019T0GA01 CALIPER SUB-ASSY., L. RR. (MSDS)
7 43022T0GA00 PAD SET, RR. (MSDS)
8 43215S9A003 PISTON
9 43227S9AE01 SPRING, PAD
10 43235SZTG01 PIN A
11 43244S9A003 RETAINER A
12 43244SG0003 RETAINER
13 43262SZTG01 PIN B
14 43352SM4951 SCREW, BLEEDER
15 43353SD5003 CAP, BLEEDER SCREW
16 45240SC2003 BOLT, FLANGE (8X22)
17 90103SJK000 BOLT, CALIPER MOUNTING
18 90113S84901 BOLT, WHEEL (ROCKNEL FASTENER)
18 90113SD4902 BOLT, WHEEL (SAGA)
18 90113SJK901 BOLT, WHEEL (THAI MEIRA)
19 90160SJK000 BOLT-WASHER (12X46)
20 93600060140H SCREW, FLAT (6X14)
