REAR BRAKE
1 01473STXA01 CALIPER SET, RR.
2 06435STXA00 SHIM SET, RR.
3 42200STXA02 BEARING ASSY., RR. HUB UNIT (MSDS)
4 42510SZAA00 DISK, RR. BRAKE DRUM IN
5 42511SP0000 CAP, MAINTENANCE HOLE
6 43018STXA01 CALIPER SUB-ASSY., R. RR.
7 43019STXA01 CALIPER SUB-ASSY., L. RR.
8 43022STXA00 PAD SET, RR.
9 43215STXA02 PISTON
10 43237STXA01 CLIP, PAD
11 43244STXA02 CLIP, PAD
12 43262STXA01 PIN, LOCK
13 45215671672 SCREW, BLEEDER
14 45219671672 CAP, BLEEDER SCREW
15 45235S9VA11 PIN, GUIDE
16 45240S01A01 BOLT
17 90103SHJ000 BOLT, CALIPER MOUNTING (12X30)
18 90113SHJA01 BOLT, WHEEL (MEIRA)
18 90113SHJA02 BOLT, WHEEL (ROCKNEL FASTENER)
19 90160SJK000 BOLT-WASHER (12X46)
20 93600060140H SCREW, FLAT (6X14)
