RADIATOR HOSE - RESERVE TANK - ATF COOLER
1 17259PG6000 COLLAR, MOUNTING
2 17260PE0670 RUBBER, MOUNTING
3 19101RP6A00 TANK, RESERVE
4 19102PM5A00 CAP, RESERVE TANK
5 19103R40A00 TUBE A, RESERVE TANK
6 19104RP6A00 TUBE B, RESERVE TANK
7 19106RSAG00 JOINT, RESERVE TANK
8 19115RP6A00 BRACKET ASSY., RESERVE TANK
9 19501RP6A00 HOSE, WATER (UPPER)
10 19502RP6A00 HOSE, WATER (LOWER)
11 19511PAHT01 CLIP, WATER HOSE (TOPY FASTENERS)
12 19519RGLA00 CLAMP, WATER HOSE (BLACK)
13 25210RP6000 PIPE C (ATF)
14 25213RP6007 HOSE (ATF)
15 25214RP6006 HOSE (555MM) (ATF)
16 25215RAA006 HOSE (155MM) (ATF) (NICHIRIN)
17 25215RP6000 HOSE (ATF)
18 25216PR3000 CLAMP, HOSE (ATF) (BLACK)
19 25216P72003 CLIP, HOSE (ATF) (BLACK)
20 25510RP6013 COOLER (ATF)
21 74172S87A00 CUSHION, RADIATOR MOUNTING (LOWER)
22 74173SJ4000 CUSHION, RADIATOR MOUNTING (UPPER)
23 74173SJ4000 CUSHION, RADIATOR MOUNTING (UPPER)
23 74173SK3E00 CUSHION, RADIATOR MOUNTING (UPPER)
24 74176ST3E00 BRACKET, RADIATOR MOUNT (UPPER)
25 90001P8F000 BOLT-WASHER, SPECIAL
26 90105RYE000 BOLT-WASHER (6X25)
27 90502PXGA00 COLLAR, AIR IN. TUBE
28 90635PT0802 CLIP, OIL PIPE
29 934040601604 BOLT-WASHER (6X16)
30 934050601604 BOLT-WASHER (6X16)
31 957010601208 BOLT, FLANGE (6X12)
