P.S. GEAR BOX
1 50220TX4A00 STIFFENER, STEERING RACK
2 52362S30003 BOOT, TIE ROD END (MUSASHI)
3 53010TX4A01 END SET, RACK
4 53413S2K013 SPRING, RACK GUIDE PRESSURE
5 53414SMA003 SCREW, RACK GUIDE
6 53416SMA003 GUIDE, STEERING RACK
7 53417SMA003 O-RING (24X3.5)
8 53418S2K003 SPRING, CONICAL
9 53419S2K003 WASHER, PLAIN
10 53434SAAG01 CLIP, STEERING TIE ROD
11 53449SYY003 BAND
12 53451SZWJ01 BOLT, FLANGE (6X12)
13 53458S2K003 NUT, LOCK
14 53492TX4A01 DUST SEAL SET, TIE ROD
15 53502TX4A00 GROMMET, STEERING
16 53535SMA003 SPACER
17 53536SMA003 WASHER, TIE ROD LOCK
18 53540TX4A01 END, TIE ROD
19 53601TX4A01 RACK, POWER STEERING
20 53602TX4A01 MOTOR SET
21 53682TX4A01 HARNESS, EPS
22 53683TX4A00 HARNESS, RADIO NOISE
23 53684TX4A01 BUSH A, STEERING GEAR BOX MOUNTING
24 53685TX4A01 BUSH B, STEERING GEAR BOX MOUNTING
25 53686TX4A01 BUSH C, STEERING GEAR BOX MOUNTING
26 53692TX4A00 BAFFLE, EPS HEAT
27 53753TX4A00 STAY, EPS HARNESS
28 53754TX4A00 STAY, CONNECTOR
29 53757TX4A00 BRACKET, HARNESS
30 53758TX4A00 BRACKET, SENSOR
31 90105SZW003 BOLT, FLANGE (8X30)
32 90108TX4A00 BOLT, GEAR BOX MOUNTING
33 90176S5A000 BOLT, FLANGE (10X30)
34 90301T0AA01 NUT, HEX. (14MM)
35 90506T0AA00 WASHER, PLAIN (12MM)
36 91351SYY003 O-RING, MOTOR
37 91540TA0003 CLIP, HARNESS BAND (100.1MM) (NATURAL)
38 91542SNA003 CLIP, HARNESS BAND (164.5MM) (DARK BLUE)
39 9403012280 NUT, HEX. (12MM)
40 9420130220 PIN, SPLIT (3.0X22)
41 957010601205 BOLT, FLANGE (6X12)
