P.S. GEAR BOX (2)
1 53010SZNA01 JOINT SET, BALL (INNER)
2 53434S87A01 CLIP
3 53436SZNA01 RUBBER, MOUNTING
4 53438SZAA00 BRACKET B, POWER STEERING RACK
5 53449S0XA01 CLAMP, BELLOWS
6 53501SZNA00 GROMMET, STEERING
7 53534S0XA02 BELLOWS
8 53535S0XA01 SPACER
9 53536S0XA01 WASHER, TAB
10 53540STXA02 END, R. TIE ROD
11 53546STXA02 BOOT, TIE ROD END
12 53560STXA02 END, L. TIE ROD
13 53601SZNA01 BOX, POWER STEERING GEAR
14 53685SHJA02 BUSH, MOUNTING
15 90107STXA50 BOLT, FLANGE (12X51)
16 90301SDBA01 NUT, HEX. (24MM)
17 90362SZAA00 NUT, FLANGE (12MM)
18 934021002008 BOLT-WASHER (10X20)
18 934121002008 BOLT-WASHER (10X20)
19 9420130220 PIN, SPLIT (3.0X22)
