HEATER UNIT
1 32157SZNA10 WIRE HARNESS, AIR CONDITIONER
2 39248692003 GASKET, HEATER
3 79021TK4A41 COVER, HEATER CORE
4 79022SZNA41 DUCT ASSY., DRIVER HEATER
5 79023TK4A41 DUCT ASSY., PASSENGER HEATER
6 79024TK4A41 GASKET, DEFROSTER DUCT
7 79025TK4A41 JOINT, DUCT
8 79026TK4A41 GASKET, FOOT DUCT
9 79027TK4A41 SEAL A
10 79030TK4A41 GASKET, RR. FACE
11 79031TK4A41 GASKET, OPENING DUCT
12 79033TK4A00 BRACKET, DRIVER CARPET PANEL
13 79106TK4A42 HEATER SUB-ASSY.
14 79115TK4A41 CORE SUB-ASSY., HEATER
15 79130TK4A41 MOTOR ASSY., PASSENGER MODE
16 79140TK4A41 MOTOR ASSY., DRIVER MODE
17 79160TK4A41 MOTOR ASSY., DRIVER TEMPERATURE
18 79170TK4A41 MOTOR ASSY., TEMPERATURE (PASSENGER)
19 79191TK4A41 CLAMP, HEATER PIPE
20 79330SJK941 TRANSISTOR, POWER
21 79731TK4A00 GROMMET, HEATER PIPE
22 80203TK4A41 PLATE, EVAPORATOR (LOWER)
23 80215TK4A41 EVAPORATOR SUB-ASSY.
24 80216TK4A41 PIPE SUB-ASSY.
25 80221TK4A41 VALVE SUB-ASSY., EXPANSION
26 80225TK4A41 INSULATOR, EVAPORATOR (LOWER)
27 80271SZNA00 HOSE ASSY., DRAIN
28 80534S84A41 ASPIRATOR
29 80560SJAA01 THERMISTOR, AIR CONDITIONER
30 80871SN7003 "O-RING (5/8"")"
31 80872SN7003 "O-RING (1/2"")"
32 90125SDGW01 BOLT, SOCKET (5X40)
33 90126S5JM01 BOLT, SOCKET (5X40)
34 90127SX0003 SCREW, TAPPING (4X16)
35 90127S84003 SCREW, TAPPING (4X16)
36 90133SR3003 SCREW-WASHER (4X16)
37 90321SV4003 NUT-WASHER (6MM) (PAINT CUTTING)
38 90661S2A003 CLIP, DRAIN HOSE
39 91507SAA003 CLIP, WIRE HARNESS (70MM) (NATURAL)
40 91531S04003 CLIP, WIRE HARNESS (44MM) (NATURAL)
41 91533STK003 CLIP, CONNECTOR (NATURAL)
42 91534SWA003 CLIP, CONNECTOR (DARK GRAY)
43 91540TA0003 CLIP, HARNESS BAND (100.1MM) (NATURAL)
44 91548SV4003 CLIP, BAND (6MM BOSS) (127MM) (NATURAL)
45 91549SE0003 HOLDER, DRAIN HOSE
46 91549TA0003 CLIP, HARNESS BAND (140.3MM) (BLACK)
47 91580SM4003 CLIP, CONNECTOR (ORANGE)
48 9407108080 NUT-WASHER (8MM)
