HEATER UNIT
1 32132S6A003 BAND, WIRE HARNESS OFFSET (20)(122.5MM) (DARK GREEN)
2 32157STXA01 SUB-WIRE HARNESS, AIR CONDITIONER
3 39248692003 GASKET, HEATER
4 79021SDGW41 GASKET, LINK
5 79021STXA01 COVER, HEATER CORE
6 79022STXA02 DUCT ASSY., DRIVER HEATER
7 79023SJCA01 DUCT ASSY., PASSENGER HEATER
8 79024SHJA01 SEAL A
9 79024SJCA01 GASKET, DEFROSTER DUCT
10 79025SHJA01 JOINT A, DUCT
11 79026SHJA01 GASKET (E)
12 79026SJCA01 GASKET, FOOT DUCT
14 79306STXA41 HEATER SUB-ASSY.
15 79115SJCA04 CORE SUB-ASSY., HEATER
16 79140SHJA01 MOTOR ASSY., MODE
17 79160STXA41 MOTOR ASSY., TEMPERATURE (DRIVER SIDE)
18 79170STXA41 MOTOR ASSY., TEMPERATURE (PASSENGER SIDE)
19 79191SHJA01 CLAMP, HEATER PIPE
20 79330SDGW51 TRANSISTOR, POWER
22 79731SDAA00 GROMMET, HEATER PIPE
24 80203SHJA01 PLATE, EVAPORATOR (LOWER)
25 80215STXA01 EVAPORATOR SUB-ASSY.
26 80216STXA01 PIPE SUB-ASSY.
27 80219S0XA01 GASKET D
28 80221STXA41 VALVE SUB-ASSY., EXPANSION
29 80271SZAA00 HOSE, DRAIN
30 80534S84A41 ASPIRATOR
31 80560SHJA01 THERMISTOR, AIR CONDITIONER
32 80871SN7003 "O-RING (5/8"") "
33 80872SN7003 "O-RING (1/2"") "
34 80873SN7003 O-RING (8MM)
35 90121S1AG01 BOLT, FLANGE
36 90127SX0003 SCREW, TAPPING (4X16)
37 90127S84003 SCREW, TAPPING (4X16)
38 90133SR3003 SCREW-WASHER (4X16)
39 90321SV4003 NUT-WASHER (6MM) (PAINT CUTTING)
41 91531S04003 CLIP, WIRE HARNESS (44MM) (NATURAL)
42 91540TA0003 CLIP, HARNESS BAND (100.1MM) (NATURAL)
43 91548SV4003 CLIP, BAND (6MM BOSS) (127MM) (NATURAL)
45 91580SM4003 CLIP, CONNECTOR (ORANGE)
46 9407108080 NUT-WASHER (8MM)
48 91549TA0003 CLIP, HARNESS BAND (140.3MM) (BLACK)
49 91593S9VA01 CLIP, FUEL TUBE
