HARNESS BAND - BRACKET
1 32110STXA01 PROTECTOR, SIDE SILL
2 32112S2K003 BAND, CABLE (90MM)
3 32120R70A01 HOLDER, CORRUGATED (25MM) (BLACK)
4 32132SM4003 BAND, WIRE HARNESS OFFSET (20)(122.5MM) (BLACK)
6 32133SM4003 BAND, HARNESS OFFSET (30) (122.5MM) (YELLOW)
7 32134SM4003 BAND, HARNESS OFFSET (10) (122.5MM) (BROWN)
8 32146SH3003 CONNECTOR, DIODE (2P)
9 32151STXA00 BRACKET, STEERING LOCK
10 32152STXA01 BRACKET (OBD-2)
12 32164STXA01 LID, INTERIOR WIRE PROTECTOR
13 32621STXA00 BRACKET, TRANSMISSION GROUND
14 32611SJCA11 BRACKET, SUB-GROUND
15 48322RYG000 STAY B, RR. DIFFERENTIAL CABLE
16 48323RYG000 STAY C, RR. DIFFERENTIAL CABLE
17 76821SE4A02 GROMMET, WASHER TUBE (DENSO)
18 90627SA5003 CLIP, WIRE HARNESS (50MM) (BLUE)(HARNESS TAPING)
20 91476SD4003 CLIP, OFFSET (21) (60MM) (BROWN)
21 91506P01003 CLIP A, HARNESS BAND (129.4MM)(DARK GRAY)
22 91506RTA003 CLIP A, HARNESS BAND (129.4MM)(DARK VIOLET)
23 91506STXA01 CLIP, HARNESS BAND (148MM) (BLACK)
24 91507P01003 CLIP B, HARNESS BAND (129.4MM)(DARK BROWN)
25 91507SNA003 CLIP, HARNESS BAND (164.5MM) (BROWN)
26 91507693003 CLIP, WIRE HARNESS (50MM) (BLACK)(HARNESS TAPING)
27 91508STXA00 CLIP, HARNESS BAND (148MM) (BLACK)
28 91531SDA003 CLIP, HARNESS BAND (145MM) (NATURAL)
29 91531SR3003 HOLDER, CONNECTOR (128.6MM) (NATURAL)
30 91531S04003 CLIP, WIRE HARNESS (44MM) (NATURAL)
31 91533SDA003 CLIP, CONNECTOR (BEIGE)
33 91533S04003 CLIP, CONNECTOR (NATURAL)
34 91533S82003 CLIP, CONNECTOR (BLACK)
38 91540S7S003 CLIP, HARNESS BAND (157.7MM) (BLACK)
40 91542SNA003 CLIP, HARNESS BAND (164.5MM) (DARK BLUE)
41 91545SNA003 CLIP, HARNESS BAND (164.5MM) (DARK BLUE)(W/SEAL)
42 91545SV4003 CLIP, HARNESS BAND (145.2MM) (NATURAL)(W/SEAL)
43 91545S2A003 CLIP, HARNESS BAND (151MM) (BROWN)(W/SEAL)
44 91547SH3003 CLIP, BAND (160MM) (NATURAL)
45 91548SV4003 CLIP, BAND (6MM BOSS) (127MM) (NATURAL)
46 91548S84003 CLIP, HARNESS BAND (128MM) (GRAY)
48 91554SM4003 HOLDER, BRACKET (RED)
49 91555SM4003 CLIP, CONNECTOR (RED)
50 91555S3VA01 HOLDER, CONNECTOR
51 91557S82003 CLIP, WIRE HARNESS (EDGE)
54 91559ST5003 CLIP, HARNESS BAND OFFSET (30)(NATURAL)
55 91559S47003 CLIP, HARNESS BAND (167MM) (NATURAL)
56 91565SEL003 CLIP, CONNECTOR (BLACK)
58 91572SM4003 CLIP, WIRE HARNESS
59 91577STXA01 CLIP, WIRE HARNESS (122.5MM) (OFFSET)(SEAL)(BLUE)
60 91902SB2003 CUSHION, WIRE HARNESS (50X100)
61 91902STXA01 PLASTER, WIRE HARNESS (50X100)
62 934050602008 BOLT-WASHER (6X20)
63 9390334380 SCREW, TAPPING (4X12)
64 957010601208 BOLT, FLANGE (6X12)
65 957010801608 BOLT, FLANGE (8X16)
66 30510TA0A01 CONDENSER (1.0 MICRO F)
67 91559S5A003 HOLDER, HARNESS (BLACK)
68 90667SB2003 CLIP, WIRE HARNESS (50MM) (GRAY)(HARNESS TAPING)
69 91705RYEA01 COVER, ENGINE CONTROL MODULE CONNECTOR
70 30510SZAA01 CONDENSER (10 MICRO F)
71 91533S5A003 CLIP, CONNECTOR (NATURAL)
72 91537SR3003 CLIP, WIRE HARNESS (127MM) (BROWN)
73 91540SV4003 CLIP, HARNESS BAND (145.2MM) (NATURAL)
74 91540STK003 CLIP, HARNESS BAND (155.3MM) (BLACK)
75 91540TA0003 CLIP, HARNESS BAND (100.1MM) (NATURAL)
77 91542TF0003 BAND, HARNESS OFFSET (20) (145MM) (DARK BLUE)
78 91551SW5003 CLIP, HARNESS BAND (151MM) (BROWN)
79 91558SAA003 CLIP, HARNESS BAND (30) (151.5MM) (BLACK)
81 91535TA0003 CLIP, CONNECTOR (DARK BROWN)
