FUEL PIPE (2)
1 16720RYEA12 HOSE, FUEL FEED
2 16725RAC003 CLAMP, FUEL HOSE (NATURAL)
3 16726RYEA01 HOLDER B, FUEL CONNECTOR (LIGHT GRAY)
4 16727RKB003 COVER, FUEL CONNECTOR
5 16731RYEA00 STAY, FUEL HOSE
6 17011STXA01 CANISTER ASSY.
7 17259PE0661 COLLAR, MOUNTING
8 17260PE0670 RUBBER, MOUNTING
9 17310SZAA01 BOX ASSY., ATMOSPHERIC
10 17311TA0A01 VALVE ASSY., CANISTER VENT SHUT
11 17321SDAA01 RETAINER
12 17321TA0A01 CAP
13 17356SZAA00 BRACKET, DRAIN JOINT
14 17357S9VA01 JOINT, DRAIN TUBE
15 17358STXA01 BRACKET, CANISTER
17 17374SZAA00 TUBE D, CANISTER DRAIN
18 17377STXA01 TUBE E, CANISTER DRAIN
19 17378STXA00 TUBE F, CANISTER DRAIN
20 17385SZAA00 TUBE A, ATMOSPHERIC
21 17386SZAA00 TUBE ASSY. B, ATMOSPHERIC
22 17578STXA00 COVER, DRAIN PIPE
23 17700STXA11 PIPE, FUEL FEED
24 17711SDCL01 RETAINER (NATURAL) (TOKAI)
25 17711S0X003 RETAINER (ORANGE) (TOKAI)
26 17711S0X931 RETAINER (BLUE GREEN) (TOKAI)
27 17711S84004 RETAINER (WHITE) (SANOH)
28 17717SZAA01 HOSE ASSY., FUEL PURGE
29 17719SZAA01 PIPE, ATMOSPHERIC
30 17720SZAA01 PIPE, FUEL PURGE
32 17724SZAA01 TUBE, FUEL PURGE
33 17743STXA11 PIPE C, CANISTER DRAIN
34 17744STXA01 TUBE, CANISTER DRAIN
35 17761SZAA00 STAY A, FUEL PIPE
36 17762STXA00 STAY B, FUEL PIPE
37 17763SZAA00 STAY C, FUEL PIPE
38 17764SZAA00 STAY D, FUEL PIPE
39 17765STXA02 STAY E, FUEL PIPE
40 37940SNAA01 SENSOR, VENT PRESSURE
41 46391SDAA01 CLIP G, BRAKE PIPE
42 75353671000 LOCK, SCREW
43 90001P7J000 BOLT, SPECIAL (6X25)
44 90361SV4003 NUT, PAINT CUTTING (6MM)
45 91391TA0A01 O-RING
46 91392TA0A01 O-RING
47 91394SDAA01 O-RING
49 91405PNA003 CLAMP, BREATHER TUBE
50 91591SHJA01 CLAMP A, FUEL PIPE (BLACK)
51 91591SZAA01 CLAMP A, FUEL PIPE
52 91593SNAA01 CLIP, DRAIN TUBE
53 91594S3VA51 CLAMP D, FUEL PIPE
54 91597SDBA01 CLAMP D, FUEL PIPE
55 91597SZAA01 CLAMP B, FUEL PIPE
56 91598STXA01 CLAMP B, FUEL PIPE
58 91599SZAA00 RUBBER A, FUEL PIPE INSULATOR
59 934050601604 BOLT-WASHER (6X16)
60 934050602004 BOLT-WASHER (6X20)
