DRIVESHAFT - HALF SHAFT
1 44014STXA51 JOINT SET, OUTBOARD (NTN)
2 44017STXA51 BOOT SET, INBOARD (RIGHT HAND SIDE)
2 44017STXA91 BOOT SET, INBOARD (NTN) (LEFT HAND SIDE)
3 44018STXA51 BOOT SET, OUTBOARD (NTN)
4 44305STXA51 DRIVESHAFT ASSY., R.
5 44306STXA51 DRIVESHAFT ASSY., L. (MSDS)
6 44310STXA61 JOINT, INBOARD
7 44310STX306 JOINT SET, INBOARD (NTN)
8 44318STXA11 BAND, OUTBOARD BOOT
9 44319STXA60 SET-RING (32X2.2)
10 44319STXA01 RING, SNAP (32X2.2)
11 44327STXA01 BAND, SHAFT BOOT
12 44327SV4305 BAND, JOINT BOOT (DOUBLE ROLLED BAND)
13 44329SV4305 BAND, SHAFT BOOT (DOUBLE ROLLED BAND)
14 44337SJCA01 RING, SNAP
15 44338S0XA01 CIRCLIP
16 44500STXA10 SHAFT ASSY., HALF
17 44517SDBA00 COVER, HEAT
19 90102SF1000 BOLT, HEX. (10X1.25)
21 90165S0X000 BOLT, FLANGE (10X37)
22 90165S5B003 BOLT, FLANGE (8X24)
23 90305S3VA11 NUT, SPINDLE
24 91057SJCA01 BEARING, HALF SHAFT (NTN)
25 91260S3VA01 SEAL, HALF SHAFT (OUTER)
26 9451038000 CIRCLIP, OUTER (38MM)
27 9452058000 CIRCLIP, INNER (58MM)
