CYLINDER BLOCK - OIL PAN
1 11000RK2A02 BLOCK ASSY., CYLINDER
2 11200RN0A00 PAN, OIL
3 11221R70A10 PLATE, BAFFLE
4 11300R70A00 CASE ASSY., OIL SEAL
5 11910RDJA00 BRACKET, ENGINE SIDE MOUNTING
6 15140P8AA00 ORIFICE ASSY., OIL CONTROL
7 15142P8AA00 O-RING (8.8X2.4)
8 15280R70A00 BODY, OIL JET
8 15280RYEA00 BODY, OIL JET (SUPERCEDED)
9 15290RJA000 BOLT, OIL JET
10 30530RNAA01 SENSOR, KNOCK
11 90001PM3003 BOLT, DRAIN PLUG (28MM)
12 90006P8AA01 BOLT-WASHER (10X109)
13 90008P8AA01 BOLT-WASHER (10X60)
14 90009PY3000 BOLT, DRAIN PLUG (14MM)
15 90009P8AA01 BOLT-WASHER (10X80)
16 90014RCAA01 BOLT-WASHER (11X105)
17 90030PH7000 BOLT, BREATHING
18 90040P8AA01 BOLT, DRAIN PLUG
19 90052RCJA00 BOLT, SPECIAL (6X22)
20 90401PR4000 WASHER, SEALING (28MM)
21 90401P8AA00 WASHER, DRAIN (18MM)
22 90715PH7000 PIN, DOWEL (13X37)
23 91214R70A01 OIL SEAL (80X98X8) (ARAI)
23 91214RCAA01 OIL SEAL (80X98X8) (NOK)
24 91308P3RT01 O-RING (26.2X2.4) (YAMADA SOMBOON)
25 9410914000 WASHER, DRAIN PLUG (14MM)
26 9430106100 PIN, DOWEL (6X10)
27 9430108140 PIN, DOWEL (8X14)
28 90001RKG000 BOLT-WASHER (6X15)
29 957010603208 BOLT, FLANGE (6X32)
30 957010605008 BOLT, FLANGE (6X50)
31 958011008508 BOLT, FLANGE (10X85)
32 958011012008 BOLT, FLANGE (10X120)
33 37500R40A01 SENSOR ASSY., CRANK
34 37503RGWA00 COVER, CRANK SENSOR
35 90139R70A00 BOLT, FLANGE (6X20.5) (GUIDE)
36 91333PNA003 O-RING (15X1.9)
37 957010601405 BOLT, FLANGE (6X14)
