BRAKE MASTER CYLINDER - MASTER POWER (KA-KC)
1 01469TX4A00 POWER SET, MASTER
2 46100TX4A02 MASTER CYLINDER ASSY.
3 46185TK8A01 O-RING
4 46191S2K000 GASKET, MASTER POWER
5 46197SHJA01 NUT-WASHER (8MM)
6 46401TX4A01 SENSOR, MASTER POWER PRESSURE
7 46402TX4A01 TUBE ASSY., MASTER POWER
8 46407SAA003 CLAMP, TUBE
9 46407STKA01 CLAMP, TUBE
10 46512S70000 PIN, PEDAL
11 46662SHJA02 CAP ASSY., RESERVOIR
12 46666SHJA01 STRAINER, MASTER CYLINDER RESERVOIR
13 46674TX4A00 BRACKET, RESERVE TANK
14 46911S70003 PIN, LOCK (8MM)
15 53729671003 CLAMP D (15.5MM)
16 934010501608 BOLT-WASHER (5X16)
17 957010601208 BOLT, FLANGE (6X12)
