BATTERY
1 17213P0GA00 RUBBER, IN. COVER MOUNT
2 17248RP6A00 SHIELD ASSY., HEAT
3 31500SD4100M BATTERY ASSY. (24F/550AMP) (MSDS)
4 31512S0XA00 PLATE, BATTERY SETTING
5 31513SM4000 BOLT, BATTERY SETTING (195MM)
6 31521SZAA00 SLEEVE, BATTERY
7 31522SZAA00 BASE, BATTERY
8 31523SZNA00 SLEEVE ASSY., BATTERY
9 32113R60003 HOLDER, CORRUGATED (10MM) (BLACK)
10 32116RKG003 HOLDER, CORRUGATED (13MM) (DARK GREEN)
11 32134SM4003 BAND, HARNESS OFFSET (10) (122.5MM) (BROWN)
12 32410SZNA00 CABLE ASSY., STARTER
13 32416TA0003 HOLDER, STARTER CABLE
14 32418RBG300 COVER, BATTERY TERMINAL
15 32600STXA03 CABLE ASSY., GROUND
16 32601SK7900 BOLT, BATTERY TERMINAL
17 32602SK7900 NUT, BATTERY TERMINAL
18 32603STXA01 HARDWARE, GROUND TERMINAL
19 90114SM4900 BOLT (6X15)
20 90149SE0003 BOLT, GROUND (6X16)
21 90337SJ4003 NUT, A.L.B.
22 91507P01003 CLIP B, HARNESS BAND (129.4MM)(DARK BROWN)
23 91507SNA003 CLIP, HARNESS BAND (164.5MM) (BROWN)
24 91540STK003 CLIP, HARNESS BAND (155.3MM) (BLACK)
25 91550S50000ZB CLIP, TAILGATE NH120L: STAR BLACK
25 91550S50000ZL CLIP, TAILGATE NH167L: GRAPHITE BLACK
26 9405006080 NUT, FLANGE (6MM)
27 9407008080 NUT-WASHER (8MM)
