B 4110 Заднее сиденье Компоненты
1 82110STKA01ZB COVER, R. RR. SEAT CUSHION (LOWER) *NH557L*(MEDIUM GRAY)
1 82110STKA01ZA COVER, R. RR. SEAT CUSHION (LOWER) *NH167L*(GRAPHITE BLACK)
2 82126STKA01 FRAME, R. RR. SEAT-BACK
3 82136STKA01 FRAME, R. RR. SEAT CUSHION
4 82138STK000 PIPE, R. SUBMARINE
5 82194STK003 DAMPER
6 82220STKA01ZA LOCK ASSY., R. RR. SEAT *NH167L*(GRAPHITE BLACK)
6 82220STKA01ZB LOCK ASSY., R. RR. SEAT *NH556L*(GRAY)
7 82225STKA01 STRIKER, RR. SEAT-BACK
8 82290STKA01 BRACKET, SEAT PIVOT (OUTER) (R)
9 82291STKA01 BRACKET, SEAT PIVOT (INNER) (R)
10 82292STKA01ZA COVER, R. PIVOT (OUTER) *NH167L*(GRAPHITE BLACK)
10 82292STKA01ZB COVER, R. PIVOT (OUTER) *NH557L*(MEDIUM GRAY)
11 82293STKA01ZA COVER, R. PIVOT (INNER) *NH167L*(GRAPHITE BLACK)
11 82293STKA01ZB COVER, R. PIVOT (INNER) *NH557L*(MEDIUM GRAY)
12 82295STKA01 BUSH, NYLON
13 82296STKA01 WASHER, PIVOT
14 82510STKA01ZA COVER, L. RR. SEAT CUSHION (LOWER) *NH167L*(GRAPHITE BLACK)
14 82510STKA01ZB COVER, L. RR. SEAT CUSHION (LOWER) *NH557L*(MEDIUM GRAY)
15 82526STKA01 FRAME, L. RR. SEAT-BACK
16 82536STKA01ZA FRAME, L. RR. SEAT CUSHION *NH167L*(GRAPHITE BLACK)
16 82536STKA01ZB FRAME, L. RR. SEAT CUSHION *NH556L*(GRAY)
17 82538STK000 PIPE, L. SUBMARINE
18 82620STKA01ZB LOCK ASSY., L. RR. SEAT *NH556L*(GRAY)
18 82620STKA01ZA LOCK ASSY., L. RR. SEAT *NH167L*(GRAPHITE BLACK)
19 82690STKA01 BRACKET, SEAT PIVOT (OUTER) (L)
20 82691STKA01 BRACKET, SEAT PIVOT (INNER) (L)
21 82692STKA01ZB COVER, L. PIVOT (OUTER) *NH557L*(MEDIUM GRAY)
21 82692STKA01ZA COVER, L. PIVOT (OUTER) *NH167L*(GRAPHITE BLACK)
22 82693STKA01ZA COVER, L. PIVOT (INNER) *NH167L*(GRAPHITE BLACK)
22 82693STKA01ZB COVER, L. PIVOT (INNER) *NH557L*(MEDIUM GRAY)
23 82914STKA01 GARNISH, RR. SEAT-BACK BELT GUIDE
24 82915STKA01 COVER, RR. SEAT CENTER ELR
25 90105S3Y000 BOLT, FLANGE (8X22)
26 90131SH3003 BOLT, TORX (8X17)
27 90135S7AJ51 BOLT-WASHER (10X25)
28 934030801608 BOLT-WASHER (8X16)
29 938910501007 Винт 5X10
30 9390125020 SCREW, TAPPING (5X8)
31 90300S84A00 NUT, SHOCK ABSORBER FLANGE (10MM)
31 9405010080 NUT, FLANGE (10MM)
32 82132STKA01 BUSH B, RR. CUSHION
