AT TRANSMISSION CASE
1 21210R8B000 CASE, TRANSMISSION
2 21230RV2A00 CAP ASSY. A, L. SIDE
3 21232RT4000 HANGER A, TRANSMISSION
4 21233RV2000 HANGER B, TRANSMISSION
5 21260RT4000 CAP ASSY. B, L. SIDE
6 21270R8E000 CAP ASSY. C, L. SIDE
7 21396P20000 CAP, BREATHER
8 21811RT4000 GASKET, TORQUE CONVERTER CASE
9 25614PK4000 BOLT, FILLER (ATF)
10 32743R8AA50 STAY, RR. TRANSMISS HOLDER
11 90030RT4003 BOLT, SEALING (10MM)
12 90041PA5000 BOLT, STUD (6X28)
13 90441PK4000 WASHER, SEALING (24MM)
14 90460RT4000 SHIM A (89MM) (0.85)
14 90461RT4000 SHIM B (89MM) (0.92)
14 90462RT4000 SHIM C (89MM) (0.99)
14 90463RT4000 SHIM D (89MM) (1.06)
14 90464RT4000 SHIM E (89MM) (1.13)
14 90465RT4000 SHIM F (89MM) (1.20)
14 90466RT4000 SHIM G (89MM) (1.27)
14 90467RT4000 SHIM H (89MM) (1.34)
14 90468RT4000 SHIM I (89MM) (1.41)
14 90469RT4000 SHIM J (89MM) (1.48)
14 90470RT4000 SHIM K (89MM) (1.55)
14 90471RT4000 SHIM L (89MM) (1.62)
14 90472RT4000 SHIM M (89MM) (1.69)
14 90473RT4000 SHIM N (89MM) (1.76)
14 90474RT4000 SHIM O (89MM) (1.83)
14 90475RT4000 SHIM P (89MM) (1.90)
14 90476RT4000 SHIM Q (89MM) (1.97)
14 90477RT4000 SHIM R (89MM) (2.04)
14 90478RT4000 SHIM S (89MM) (2.11)
14 90479RT4000 SHIM T (89MM) (2.18)
15 90612RT4000 RING, SNAP (100MM)
16 90614RT4000 RING, SNAP (72MM)
17 91002RV2005 BEARING, BALL (33X100X19.5/15)
18 91004RV2005 BEARING, BALL (27X72X19/17)
19 91010RV2005 BEARING, BALL (12X28X7)
20 91106RT4003 BEARING, NEEDLE (23X40X31.5)
21 91205RT4003 OIL SEAL (42X58X12.5)
22 91302RDK003 O-RING (28X2.2) (NOK)
23 91317RT4003 O-RING (83X2.3)
24 91318RT4003 O-RING (116.7X2.2)
25 957010601208 BOLT, FLANGE (6X12)
26 957010602008 BOLT, FLANGE (6X20)
27 957010802008 BOLT, FLANGE (8X20)
28 957010804008 BOLT, FLANGE (8X40)
29 957010805508 BOLT, FLANGE (8X55)
30 957010807508 BOLT, FLANGE (8X75)
31 957011004008 BOLT, FLANGE (10X40)
32 957011005008 BOLT, FLANGE (10X50)
33 957011007008 BOLT, FLANGE (10X70)
34 957011008008 BOLT, FLANGE (10X80)
35 957011009508 BOLT, FLANGE (10X95)
