AT TRANSFER (6AT)
1 21421RJB000 PLATE, BREATHER
2 21431RJB000 GUTTER, OIL
3 29000RT4000 TRANSFER ASSY.
4 29311RJB000 SPACER, PINION
5 29321RJB000 WASHER, THRUST (32.1X37X1)
6 29412RT4010 TUBE A, BREATHER
7 29413RT4010 TUBE B, BREATHER
8 29421RDK000 CLAMP, BREATHER TUBE
9 29431RK4000 STAY, TRANSFER BREATHER
10 29610RT4000 FLANGE, COMPANION
11 41931RMH000 JOINT, BREATHER
12 41935RWE013 BOX, BREATHER TUBE
13 90026PS5000 BOLT, FLANGE (10X105)
14 90081PE9000 BOLT, PLUG (20MM)
15 90203PCY000 NUT, HEX. (27MM)
16 90402PL9000 WASHER, SPRING (27MM)
17 90705PF4000 PIN, DOWEL (14X20)
18 91201RJB003 OIL SEAL (42X67X9) (NOK)
19 91202RDK003 OIL SEAL (48X67X7.5)
20 91301PCY003 O-RING (28X2.6)
21 91302PCY003 RING, BACK-UP (28MM)
22 91303RDK003 O-RING (120.7X2.4) (NOK)
23 9410920000 WASHER, DRAIN PLUG (20MM)
24 957010601008 BOLT, FLANGE (6X10)
25 957010601608 BOLT, FLANGE (6X16)
26 957010802508 BOLT, FLANGE (8X25)
27 957011005008 BOLT, FLANGE (10X50)
