AT TORQUE CONVERTER CASE
1 21110RT4315 CASE, TORQUE CONVERTER
2 21220RT4000 PLATE, OIL CATCH
3 22730RT4010 PIPE ASSY., FEED
4 22760RT4000 PIPE A, JOINT
5 22770RT4000 PIPE B, JOINT
6 23225RT4000 PLATE, OIL GUIDE (T)
7 23235RDK000 PLATE, OIL GUIDE
8 23235RT4000 PLATE, OIL GUIDE (I)
9 23236RT4010 COLLAR ASSY., OIL GUIDE
10 25421RT4000 PLATE, BAFFLE
11 25422PN6801 MAGNET, TRANSMISSION
12 27430RPC003 BOLT, AIR CHECK
13 90001RT4000 BOLT, FLANGE (6X95)
14 90002RT4000 BOLT, FLANGE (6X30)
15 90030RT4003 BOLT, SEALING (10MM)
16 90041RT4003 BOLT, SEALING (10MM)
17 90081PX4003 BOLT, PLUG (18MM)
18 90471PX4000 WASHER, DRAIN PLUG (18MM)
19 90701RJB000 PIN, DOWEL (14X25)
20 9430114200 PIN, DOWEL (14X20)
21 91001R97003 BEARING, BALL (41X70X9.7/8.5)
22 91006RT4003 BEARING, BALL (25X61X15)
23 91011RT4004 BEARING, BALL (15X32X8)
24 91101RDK003 BEARING, NEEDLE (32X63X19)
25 91102RT4003 BEARING, NEEDLE (40.5X74X23)
26 91104RT4003 BEARING, NEEDLE (28.6X40.8X13)
27 91105RT4003 BEARING, NEEDLE (32X44X14.5)
28 91201RDK003 OIL SEAL (48X65X7.5) (NOK)
29 91206RT4003 OIL SEAL (37X56X8)
30 91207RT4003 OIL SEAL (51X70X7.5)
31 91301PWR003 O-RING (16.7X1.9) (NOK)
32 91303PWR003 O-RING (43X1.9) (NOK)
33 91311PA9004 O-RING (7.7X1.9) (NOK)
34 9430110160 PIN, DOWEL (10X16)
35 9430210200 PIN, DOWEL (10X20)
36 957010601808 BOLT, FLANGE (6X18)
37 957010610008 BOLT, FLANGE (6X100)
