AT THIRD SHAFT - CLUTCH (4TH) (6AT)
1 22660RT4003 CLUTCH ASSY., FOURTH
2 22816RT4004 RING, SEAL (35MM)
3 23240RT4000 SHAFT, THIRD
4 23471RT4010 GEAR, THIRDSHAFT FOURTH
5 23505RT4000 GEAR, THIRDSHAFT SIXTH
6 23531RT4000 GEAR, THIRDSHAFT REVERSE
7 23565RT4000 SELECTOR, REVERSE GEAR
8 23566RT4000 HUB, SELECTOR
9 90202RT4000 NUT, FLANGE (24MM) (LEFT HAND THREAD)
10 90402RT4000 WASHER (27X40X3.5)
11 90406RT4000 WASHER A (8.515MM)
11 90407RT4000 WASHER B (8.540MM)
11 90408RT4000 WASHER C (8.565MM)
11 90409RT4000 WASHER D (8.590MM)
11 90410RT4000 WASHER E (8.615MM)
11 90411RT4000 WASHER F (8.640MM)
12 90435RT4000 COTTER (36MM)
13 90436RT4000 RETAINER, COTTER
14 90451RT4000 COLLAR (28X35X51.5)
15 90605RT4000 CIRCLIP (OUTER) (37)
16 91024RT4005 BEARING, NEEDLE (45X50X25)
17 91025RT4005 BEARING, NEEDLE (37X42X25)
18 91026RT4003 BEARING, NEEDLE (35X41X32)
19 91037RT4005 BEARING, THRUST NEEDLE (49X66X3)
20 91320RT4003 O-RING (35.5X1.9)
