AT SHIFT FORK
1 21255RT4000 CAP, COOLER RETURN
2 22750RT4000 PIPE, LUBRICATION
3 24000RT4000 SHAFT ASSY., CHANGE CONTROL
4 24111RT4000 FORK, REVERSE SHIFT
5 24282634000 BOLT, SHAFT FORK SETTING
6 24560RT4000 HOLDER, PARKING
7 24630RT4000 ARM, CHANGE DETENT
8 24635P6H000 SHAFT, CHANGE DETENT ARM
9 25313RT4000 PIPE (10X70)
10 25420RV2003 STRAINER ASSY. (ATF)
11 90002RT4000 BOLT, FLANGE (6X30)
12 90433639000 WASHER, LOCK (6MM)
13 91308PW4003 O-RING (21.8X1.9)
14 9430308140 PIN, DOWEL (8X14)
15 9430312200 PIN, DOWEL (12X20)
16 957010601808 BOLT, FLANGE (6X18)
17 957010602508 BOLT, FLANGE (6X25)
18 957010807008 BOLT, FLANGE (8X70)
19 957010808508 BOLT, FLANGE (8X85)
