AT SENSOR - SOLENOID - SECONDARY BODY
1 22740RT4000 PIPE ASSY. (11X27)
2 27700RT4000 BODY ASSY., SECONDARY VALVE
3 28252RT4000 GASKET, LINEAR SOLENOID
6 28500RT4003 SOLENOID ASSY. (C)
7 28600R94004 SWITCH ASSY., AT OIL PRESSURE
8 28610R36004 SWITCH ASSY., AT OIL PRESSURE
9 28650RT4003 SENSOR ASSY., TEMPERATURE (ATF)
10 28810RWE003 PICK-UP ASSY. (MATSUSHITA)
11 90041RT4003 BOLT, SEALING (10MM)
12 90425RT4000 GASKET (10MM)
13 90471PW7A00 GASKET (10MM)
14 91301P6H003 O-RING (7.6X1.9) (KEIHIN)
15 91302P7WA00 O-RING (9.6X1.9)
16 91303P6H003 O-RING (11.7X1.9) (KEIHIN)
17 91303RAY003 O-RING (12X2.4) (NOK)
18 91309PX4003 O-RING (16X2.1) (NOK)
19 91311PA9004 O-RING (7.7X1.9) (NOK)
20 957010601408 BOLT, FLANGE (6X14)
21 957010601808 BOLT, FLANGE (6X18)
22 957010603008 BOLT, FLANGE (6X30)
