AT MAINSHAFT - CLUTCH (3RD-6TH)
1 22650RT4013 CLUTCH ASSY., THIRD & SIXTH
2 22814RT4003 SEAL, RING (41MM)
3 23210RT4000 MAINSHAFT
4 23455RT4000 GEAR, MAINSHAFT THIRD
4 23455RT4010 GEAR, MAINSHAFT THIRD
5 23461RT4000 GEAR, MAINSHAFT FOURTH
6 23501RT4315 GEAR SET, MAINSHAFT SIXTH
7 90201RT4000 NUT, FLANGE (30MM)
8 90401RT4000 WASHER (33X46X3.9)
9 90448RT4000 COLLAR (34X42X33.5)
10 90621PRP000 CIRCLIP, OUTER (32MM)
11 91017RT4003 BEARING, NEEDLE (32X40X23)
12 91023RT4005 BEARING, NEEDLE (42X49X23)
13 91035RT4005 BEARING, THRUST NEEDLE (47X64X3)
14 91036RT4005 BEARING, THRUST NEEDLE (42X63.5X3.5)
15 91320RT4003 O-RING (35.5X1.9)
