AT COUNTERSHAFT
1 23221RV2010 COUNTERSHAFT
2 23420RT4000 GEAR ASSY., COUNTERSHAFT LOW
3 23427RT4000 GEAR, PARKING
4 23441RT4010 GEAR, COUNTERSHAFT SECOND
5 23454RT4000 GEAR, REVERSE IDLE
6 23491RT4000 GEAR, COUNTERSHAFT FIFTH
7 90011RT4000 BOLT, SPECIAL (20X25) (LEFT HAND THREAD)
8 90013RT4000 BOLT, SPECIAL (8X35)
9 90403RV2A00 WASHER (42.5X52.5) (X2.5)
10 90450RT4000 COLLAR (42.5X47.5) (X66.5)
11 90530RT4000 SHIM A (42.5MM) (1.82)
11 90531RT4000 SHIM B (42.5MM) (1.86)
11 90532RT4000 SHIM C (42.5MM) (1.90)
11 90533RT4000 SHIM D (42.5MM) (1.94)
11 90534RT4000 SHIM E (42.5MM) (1.98)
11 90535RT4000 SHIM F (42.5MM) (2.02)
11 90536RT4000 SHIM G (42.5MM) (2.06)
11 90537RT4000 SHIM H (42.5MM) (2.10)
11 90538RT4000 SHIM I (42.5MM) (2.14)
11 90539RT4000 SHIM J (42.5MM) (2.18)
11 90540RT4000 SHIM K (42.5MM) (2.22)
11 90541RT4000 SHIM L (42.5MM) (2.26)
12 90613RT4000 RING, SNAP (78MM)
13 91003RT4005 BEARING, BALL (30X78X31/25)
14 91021RT4003 BEARING, NEEDLE (53X57X20)
