AT корпус аккумулятора ('01-'02)
1 22744PY4000 PIPE (10X60)
2 27251PCJ000 VALVE, LUBRICATION CHECK
3 27524P6H000 CLIP, CAP
4 27561PAX000 PISTON, LOW ACCUMULATOR
5 27561P7W000 PISTON, LOW ACCUMULATOR
6 27562P7W000 SPRING A, LOW ACCUMULATOR
7 27564P7W000 SPRING B, LOW ACCUMULATOR
8 27581P7W000 SPRING A, SECOND ACCUMULATOR
9 27584P7W000 SPRING B, SECOND ACCUMULATOR
10 27815P7W000 COVER, ACCUMULATOR BODY
11 27860P7W000 BODY COMP., ACCUMULATOR
12 90602P7W000 RING, SNAP (37MM)
13 90607P6H000 RING, SNAP (26MM)
14 91318PA9003 O-RING (23.5X2.1) (ARAI)
15 91331PC9003 O-RING (21.2X2.4) (ARAI)
16 91344580000 O-RING (31X2.7) (ARAI)
17 9430108140 PIN, DOWEL (8X14)
18 957010601608 Болт (6X16)
19 957010603508 BOLT, FLANGE (6X35)
20 957010605008 BOLT, FLANGE (6X50)
21 957010606008 BOLT, FLANGE (6X60)
22 9621107000 BALL, STEEL (#7) (7/32)
    23.1 KB · Просмотры: 202
