43 HEATER UNIT
1 79021TR0A01 SEAL A
2 79027TX4A00 STAY, HVAC
3 79106TX4A41 HEATER SUB-ASSY.
4 79115TX4A01 CORE SUB-ASSY., HEATER
5 79140TR0A01 MOTOR ASSY., MODE SERVO
6 79160T0AA41 MOTOR ASSY., AIR MIX (DRIVER SIDE)
7 79170T0AA41 MOTOR ASSY., AIR MIX (PASSENGER SIDE)
8 79330TR0A01 TRANSISTOR, POWER
9 79731SDAA00 GROMMET, HEATER PIPE
10 80211TX4A41 EVAPORATOR
11 80221TX4A41 VALVE ASSY., EXPANSION
13 80271TX4A00 HOSE, DRAIN
14 80534S84A41 ASPIRATOR
15 80542TX4A41 HOSE B, ASPIRATOR
16 80560TX4A41 THERMISTOR, AIR CONDITIONER
17 80566SMA003 CLIP, EVAPORATOR SENSOR
18 80650TX4A40 SUB-WIRE HARNESS, AIR CONDITIONER
19 80871SN7003 "O-RING (5/8"") "
19 80871ST7000 "O-RING (5/8"") (SUPERCEDED)"
20 80872ST7000 "O-RING (1/2"") "
21 90126S5A003 BOLT, SOCKET (5X40)
22 90127S84003 SCREW, TAPPING (4X16)
23 90127SX0003 SCREW, TAPPING (4X16)
24 90321SV4003 NUT-WASHER (6MM) (PAINT CUTTING)
25 90361SV4003 NUT, PAINT CUTTING (6MM)
26 90661S2A003 CLIP, DRAIN HOSE
27 91533STK003 CLIP, CONNECTOR (NATURAL)
28 91542SNA003 CLIP, HARNESS BAND (164.5MM) (DARK BLUE)
29 91549TA0003 CLIP, HARNESS BAND (140.3MM) (BLACK)
30 91580SM4003 CLIP, CONNECTOR (ORANGE)
31 9407108080 NUT-WASHER (8MM)
