43 HEATER UNIT
1 39248692003 GASKET, HEATER
2 79021SNAA01 SEAL A
3 79101STKA41 DUCT ASSY., HEATER (DRIVER SIDE)
4 79102STKA41 DUCT ASSY., HEATER (PASSENGER SIDE)
5 79103STKA41 GASKET SET
6 79104SNAA01 GASKET
7 79106STKA43 HEATER SUB-ASSY.
8 79107SNAA01 COVER, HEATER PIPE
9 79108STKA41 PLATE, EVAPORATOR (LOWER)
10 79109SNAA01 INSULATOR, EVAPORATOR (LOWER)
11 79110SNEA01 CORE SUB-ASSY., HEATER
12 79140STKA01 MOTOR ASSY., MODE
13 79160STKA41 MOTOR ASSY., AIR MIX (DRIVER SIDE)
14 79170STKA41 MOTOR ASSY., AIR MIX (PASSENGER SIDE)
15 79308SNAA01 JOINT SET, DUCT
16 79330SNAA01 TRANSISTOR, POWER
17 79544STKA01 CABLE, WATER VALVE CONTROL
18 79731S5A000 GROMMET, HEATER PIPE
19 79770SE0000 GROMMET, WATER VALVE CABLE
20 80211STKA41 EVAPORATOR
21 80221STKA41 VALVE ASSY., EXPANSION
22 80271STKA00 HOSE A, DRAIN
23 80272STKA01 HOSE B, DRAIN
24 80534S84A41 ASPIRATOR
25 80542STKA41 HOSE B, ASPIRATOR
26 80545SJD940 JOINT, ASPIRATOR HOSE
27 80560STKA41 THERMISTOR, AIR CONDITIONER
28 80566SMA003 CLIP, EVAPORATOR SENSOR
29 80650STKA01 SUB-HARNESS, AIR CONDITIONER
30 80871ST7000 "O-RING (5/8"") "
31 80872ST7000 "O-RING (1/2"") "
32 90121SNAA00 BOLT, STUD (6X49)
33 90121SR3003 SCREW, TAPPING (5X12)
34 90126S5A003 BOLT, SOCKET (5X40)
35 90127SX0003 SCREW, TAPPING (4X16)
36 90133SR3003 SCREW-WASHER (4X16)
37 90321SV4003 NUT-WASHER (6MM) (PAINT CUTTING)
38 91540STK003 CLIP, HARNESS BAND (155.3MM) (BLACK)
39 90661S2A003 CLIP, DRAIN HOSE
40 91533S04003 CLIP, CONNECTOR (NATURAL)
41 91541S0A003 CLIP, HARNESS BAND (145MM) (BLACK)
42 91550SM4003 CLIP, WIRE HARNESS
43 9407108080 NUT-WASHER (8MM)
44 91580SM4003 CLIP, CONNECTOR (ORANGE)
