27 CONTROL UNIT (ENGINE ROOM) (1)
1 32146SH3003 CONNECTOR, DIODE (2P)
2 37820RWCA81 CONTROL MODULE, ENGINE (REWRITABLE)
3 37821RWCA00 BRACKET, PCM
4 37823RWCA00 COVER, PCM
5 38100STKA02 HORN ASSY. (LOW)
6 38150STKA02 HORN ASSY. (HIGH)
7 38182STKA02 COVER, MULTI RELAY (S)(RELAY/FUSE)
8 38211SNAA11 FUSE, BLOCK (30A)
9 38211SNAA21 FUSE, BLOCK (40A)
10 38221SNAA31 FUSE, BLADE (7.5A)
11 38221SNAA41 FUSE, BLADE (10A)
12 38221SNAA51 FUSE, BLADE (15A)
13 38221SNAA61 FUSE, BLADE (20A)
14 38221SNAA81 FUSE, BLADE (30A)
15 38231SNAA11 FUSE A, MULTI BLOCK (80A/50A)
16 38231STKA01 FUSE A, MULTI BLOCK (100A/30A)
17 38232SDAA01 FUSE B, MULTI BLOCK (40A/50A)
18 38232SMGE01 FUSE B, MULTI BLOCK (40A/20A)
19 38235TA0A01 PULLER, FUSE
20 38250STKA02 BOX ASSY., RELAY
21 38251STKA00 BRACKET, RELAY BOX
22 38255SNA003 DETECTOR UNIT, ELECTRONIC LOAD
23 38256STKA03 COVER, RELAY BOX (UPPER)
24 38257SNAA02 COVER (LOWER)
25 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (VACUUM PUMP)
25 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (STARTER CUT)
25 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (RR. ACCESSORY)
25 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (RADIATOR FAN)
25 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (POWER WINDOWS)
25 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (PLUS BATTERY CUT)
25 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (MAGNETIC CLUTCH)
25 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (LAF SENSOR)
25 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (CONDENSER FAN)
25 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (DRIVE BY WIRE)
25 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (FR. ACCESSORY)
25 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (FR. FOG)
25 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (HEATED MIRROR)
25 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (HEATED SEAT)
26 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (PLUS BATTERY CUT)
26 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (POWER WINDOWS)
26 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (RADIATOR FAN)
26 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (RR. ACCESSORY)
26 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (STARTER CUT)
26 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (VACUUM PUMP)
26 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (MAGNETIC CLUTCH)
26 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (LAF SENSOR)
26 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (HEATED SEAT)
26 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (HEATED MIRROR)
26 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (FR. FOG)
26 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (FR. ACCESSORY)
26 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (DRIVE BY WIRE)
26 39794SDAA03 RELAY ASSY., POWER (MICRO ISO)(OMRON) (CONDENSER FAN)
27 72695SZ3003 BUZZER ASSY., KEYLESS
28 90114SM4900 BOLT (6X15)
29 90129SX8003 SCREW-WASHER (5X12)
30 90150S84003 BOLT, GROUND (8X16)
31 91565SD5003 CLIP, CONNECTOR (NATURAL)
32 91602SL0000 GROMMET, SCREW (5MM)
33 934030601208 BOLT-WASHER (6X12)
34 934030602008 BOLT-WASHER (6X20)
35 9390125320 SCREW, TAPPING (5X16)
36 957010601208 BOLT, FLANGE (6X12)
