25 CRANKSHAFT - PISTON
1 13010RWCA00 PISTON SET A (STD)
1 13020RWCA00 PISTON SET B (STD)
1 13030RWCA00 PISTON SET (OVER SIZE) (0.25)
2 13011RWCA01 RING SET, PISTON (STD)
2 13021RWCA01 RING SET, PISTON (OVER SIZE) (0.25)
3 13111RAAA00 PIN, PISTON
4 13115PRBA00 CLIP, PISTON PIN
5 13204RWCA01 BOLT, CONNECTING ROD
6 13210RWCA01 ROD, CONNECTING
7 13211RBB003 BEARING A, CONNECTING ROD (BLUE) (DAIDO)
7 13212RBB003 BEARING B, CONNECTING ROD (BLACK) (DAIDO)
7 13213RBB003 BEARING C, CONNECTING ROD (BROWN) (DAIDO)
7 13214RBB003 BEARING D, CONNECTING ROD (GREEN) (DAIDO)
7 13215RBB003 BEARING E, CONNECTING ROD (YELLOW) (DAIDO)
7 13216RBB003 BEARING F, CONNECTING ROD (PINK) (DAIDO)
7 13217RBB003 BEARING G, CONNECTING ROD (RED) (DAIDO)
8 13310RWCA00 CRANKSHAFT
9 13321PNA003 BEARING A, MAIN (UPPER) (BLUE)(DAIDO)
9 13322PNA003 BEARING B, MAIN (UPPER) (BLACK) (DAIDO)
9 13323PNA003 BEARING C, MAIN (UPPER) (BROWN) (DAIDO)
9 13324PNA003 BEARING D, MAIN (UPPER) (GREEN) (DAIDO)
9 13325PNA003 BEARING E, MAIN (UPPER) (YELLOW) (DAIDO)
9 13326PNA003 BEARING F, MAIN (UPPER) (PINK)(DAIDO)
10 13331ZY6003 WASHER, THRUST (TAIHO) (SUPERCEDED)
10 13331ZY6013 WASHER, THRUST
11 13341PNA003 BEARING A, MAIN (LOWER) (BLUE)(DAIDO)
11 13342PNA003 BEARING B, MAIN (LOWER) (BLACK) (DAIDO)
11 13343PNA003 BEARING C, MAIN (LOWER) (BROWN) (DAIDO)
11 13344PNA003 BEARING D, MAIN (LOWER) (GREEN) (DAIDO)
11 13345PNA003 BEARING E, MAIN (LOWER) (YELLOW) (DAIDO)
11 13346PNA003 BEARING F, MAIN (LOWER) (PINK)(DAIDO)
12 13620RAAA02 SPROCKET, CHAIN DRIVE
13 13622RAAA01 PLATE, CRANK PULSER
14 13810RWCA01 PULLEY, CRANKSHAFT
15 90017RWCA01 BOLT-WASHER (16X49)
16 90704PNA000 KEY (4.5X21)
17 9430110120 PIN, DOWEL (10X12)
