25 CRANKSHAFT - PISTON
1 13010RWCA00 PISTON SET A (STD)
1 13020RWCA00 PISTON SET B (STD)
1 13030RWCA00 PISTON SET (OVER SIZE) (0.25)
2 13011RWCA01 RING SET, PISTON (STD)
2 13021RWCA01 RING SET, PISTON (OVER SIZE) (0.25)
3 13111RAAA00 PIN, PISTON
4 13115PRBA00 CLIP, PISTON PIN
5 13204RWCA01 BOLT, CONNECTING ROD
6 13210RWCA01 ROD, CONNECTING
7 13211RBB003 BEARING A, CONNECTING ROD (BLUE) (DAIDO)
7 13212RBB003 BEARING B, CONNECTING ROD (BLACK) (DAIDO)
7 13213RBB003 BEARING C, CONNECTING ROD (BROWN) (DAIDO)
7 13214RBB003 BEARING D, CONNECTING ROD (GREEN) (DAIDO)
7 13215RBB003 BEARING E, CONNECTING ROD (YELLOW) (DAIDO)
7 13216RBB003 BEARING F, CONNECTING ROD (PINK) (DAIDO)
7 13217RBB003 BEARING G, CONNECTING ROD (RED) (DAIDO)
8 13310RWCA00 CRANKSHAFT
9 13321RAAA02 BEARING A, MAIN (UPPER) (BLUE)(GLACIER DAIDO) (SUPERCEDED)
9 13322RAAA02 BEARING B, MAIN (UPPER) (BLACK) (GLACIER DAIDO) (SUPERCEDED)
9 13323RAAA02 BEARING C, MAIN (UPPER) (BROWN) (GLACIER DAIDO) (SUPERCEDED)
9 13324RAAA02 BEARING D, MAIN (UPPER) (GREEN) (GLACIER DAIDO) (SUPERCEDED)
9 13325PNA003 BEARING E, MAIN (UPPER) (YELLOW) (DAIDO)
9 13325RAAA02 BEARING E, MAIN (UPPER) (YELLOW) (GLACIER DAIDO) (SUPERCEDED)
9 13326RAAA02 BEARING F, MAIN (UPPER) (PINK)(GLACIER DAIDO) (SUPERCEDED)
10 13331ZY6003 WASHER, THRUST (TAIHO) (SUPERCEDED)
10 13331ZY6013 WASHER, THRUST
11 13341RAAA02 BEARING A, MAIN (LOWER) (BLUE)(GLACIER DAIDO) (SUPERCEDED)
11 13342RAAA02 BEARING B, MAIN (LOWER) (BLACK) (GLACIER DAIDO) (SUPERCEDED)
11 13343RAAA02 BEARING C, MAIN (LOWER) (BROWN) (GLACIER DAIDO) (SUPERCEDED)
11 13344RAAA02 BEARING D, MAIN (LOWER) (GREEN) (GLACIER DAIDO) (SUPERCEDED)
11 13345RAAA02 BEARING E, MAIN (LOWER) (YELLOW) (GLACIER DAIDO) (SUPERCEDED)
11 13346RAAA02 BEARING F, MAIN (LOWER) (PINK)(GLACIER DAIDO) (SUPERCEDED)
12 13620RAAA02 SPROCKET, CHAIN DRIVE
13 13622RAAA01 PLATE, CRANK PULSER
14 13810RWCA01 PULLEY, CRANKSHAFT
15 90017RWCA01 BOLT-WASHER (16X49)
16 90704PNA000 KEY (4.5X21)
17 9430110120 PIN, DOWEL (10X12)
