24 WATER HOSE
1 12207PC6300 WASHER, SEALING (16MM)
2 19500RWCA00 JOINT, TUBE
3 19504RWCA00 HOSE, BYPASS INLET (A)
4 19509P72003 CLAMP, ELECTRONIC AIR CONTROL VALVE HOSE
5 19509RWCA00 HOSE, THROTTLE BODY OUTLET
6 19510RWCA00 PIPE, HEATER
7 19550RWCA00 PIPE, EX. MANIFOLD WATER INLET
8 19551RWCA00 HOSE A, EX. MANIFOLD WATER INLET
9 19552RWCA00 HOSE B, EX. MANIFOLD WATER INLET
10 19555RWCA00 PIPE, EX. MANIFOLD WATER OUTLET CONNECTING
11 19556RWCA00 HOSE, EX. MANIFOLD WATER OUTLET
12 36204RWCA01 CLAMP, TUBE
13 90028PNB003 BOLT, SPECIAL (6X20.5) (GUIDE)
14 91316PHM003 O-RING (13.6X3.8)
15 91315PNA003 O-RING (19.3X3.8)
16 91407RWCA00 CLAMP, TUBE (D12.5)
17 91408RWCA01 CLIP, WATER HOSE
18 91409RWCA01 CLIP, WATER HOSE
19 957010601208 BOLT, FLANGE (6X12)
20 957010801608 BOLT, FLANGE (8X16)
