24 CRANKSHAFT - PISTON
1 13010R70A10 PISTON SET (STD)
1 13030R70A10 PISTON SET (OVER SIZE) (0.25)
1 13030RV0A00 PISTON SET (OVER SIZE) (0.25)
2 13011RV0A01 RING SET, PISTON (STD) (ALLIED RING)
2 13021R70A11 RING SET, PISTON (OVER SIZE) (0.25) (RIKEN)
2 13021RV0A01 RING SET, PISTON (OVER SIZE) (0.25) (ALLIED RING)
3 13111P8AA00 PIN, PISTON
4 13115PRBA00 CLIP, PISTON PIN
5 13204P8AA01 BOLT, CONNECTING ROD
6 13210R70A00 ROD, CONNECTING
7 13211P8FA11 BEARING A, CONNECTING ROD (BLACK) (TAIHO)
7 13212P8FA11 BEARING B, CONNECTING ROD (BROWN) (TAIHO)
7 13213P8FA11 BEARING C, CONNECTING ROD (GREEN) (TAIHO)
7 13214P8FA11 BEARING D, CONNECTING ROD (YELLOW) (TAIHO)
7 13215P8FA11 BEARING E, CONNECTING ROD (PINK) (TAIHO)
8 13310R70A00 CRANKSHAFT
9 13321RYEA02 BEARING A, MAIN (UPPER) (BLACK) (TAIHO)
9 13322RYEA02 BEARING B, MAIN (UPPER) (BROWN) (TAIHO)
9 13323RYEA02 BEARING C, MAIN (UPPER) (GREEN) (TAIHO)
9 13324RYEA02 BEARING D, MAIN (UPPER) (YELLOW) (TAIHO)
9 13325RYEA02 BEARING E, MAIN (UPPER) (PINK)(TAIHO)
9 13326RYEA01 BEARING F, MAIN (UPPER) (RED) (TAIHO)
10 13331P8AA01 WASHER, THRUST
11 13341RYEA02 BEARING A, MAIN (LOWER) (BLACK) (TAIHO)
11 13342RYEA02 BEARING B, MAIN (LOWER) (BROWN) (TAIHO)
11 13343RYEA02 BEARING C, MAIN (LOWER) (GREEN) (TAIHO)
11 13344RYEA02 BEARING D, MAIN (LOWER) (YELLOW) (TAIHO)
11 13345RYEA02 BEARING E, MAIN (LOWER) (PINK)(TAIHO)
11 13346RYEA01 BEARING F, MAIN (LOWER) (RED) (TAIHO)
12 13621RV0A01 PULLEY, TIMING BELT DRIVE
13 13622RJA000 PLATE, TIMING BELT GUIDE
14 13810R70A01 PULLEY, CRANKSHAFT
15 13910R70A00 PLATE, CRANK PULSER
16 90013R70A01 BOLT, SPECIAL (8X11)
17 90017RJA003 BOLT-WASHER (16X49)
18 90704RCAA00 KEY (4.5X24)
