23 WATER PUMP
1 19200RWCA01 WATER PUMP
2 19222RAAA01 GASKET, WATER PUMP
3 19224RWCA01 PULLEY, WATER PUMP
4 19301RTA003 THERMOSTAT ASSY. (FUJI SEIKO)
5 19305RAAA01 SEAL, THERMOSTAT COVER (FUJI BELLOWS)
6 19320RWCA00 CASE, THERMOSTAT
7 19322PCX003 O-RING (43.8X3.1)
8 19322RWCA01 SEAL, THERMOSTAT CASE
9 19352RWCA01 SEAL, WATER OUTLET
10 19360RWCA00 LOWER WATER OUTLET
11 19365RWCA00 UPPER WATER OUTLET
12 19410RWCA00 PASSAGE, WATER
13 32741RWCA00 STAY E, ENGINE HARNESS
14 37870RWCA01 SENSOR ASSY., WATER TEMPERATURE (PANASONIC)
15 90013PCX000 BOLT, SPECIAL (6X12)
16 90050PNA003 BOLT, SPECIAL (6X19) (NIPPON THERMOSTAT)
17 91307PLC004 O-RING (9.5X1.9) (MATSUSHITA)
18 92900100600B BOLT, STUD (10X60)
19 92900101000B BOLT, STUD (10X100)
20 9405010080 NUT, FLANGE (10MM)
21 957010601208 BOLT, FLANGE (6X12)
22 957010602008 BOLT, FLANGE (6X20)
23 957010602508 BOLT, FLANGE (6X25)
24 957010603008 BOLT, FLANGE (6X30)
25 957010606508 BOLT, FLANGE (6X65)
26 957010608008 BOLT, FLANGE (6X80)
27 957011010508 BOLT, FLANGE (10X105)
