23 REAR SEAT COMPONENTS
1 82110STKA01ZB COVER, R. RR. SEAT CUSHION (LOWER) NH557L: MEDIUM GRAY
1 82110STKA01ZC COVER, R. RR. SEAT CUSHION (LOWER) NH690L: PREMIUM BLACK
2 82126STKA01 FRAME, R. RR. SEAT-BACK
3 82136STKA01 FRAME, R. RR. SEAT CUSHION
4 82138STK000 PIPE, R. SUBMARINE
5 82194STK003 DAMPER
6 82220STKA02ZB LOCK ASSY., R. RR. SEAT NH556L: GRAY
6 82220STKA02ZC LOCK ASSY., R. RR. SEAT NH690L: PREMIUM BLACK
7 82225STKA01 STRIKER, RR. SEAT-BACK
8 82290STKA01 BRACKET, SEAT PIVOT (OUTER) (R)
9 82291STKA01 BRACKET, SEAT PIVOT (INNER) (R)
10 82292STKA01ZB COVER, R. PIVOT (OUTER) NH557L: MEDIUM GRAY
10 82292STKA01ZC COVER, R. PIVOT (OUTER) NH690L: PREMIUM BLACK
11 82293STKA01ZB COVER, R. PIVOT (INNER) NH557L: MEDIUM GRAY
11 82293STKA01ZC COVER, R. PIVOT (INNER) NH690L: PREMIUM BLACK
12 82295STKA01 BUSH, NYLON
13 82296STKA01 WASHER, PIVOT
14 82510STKA01ZB COVER, L. RR. SEAT CUSHION (LOWER) NH557L: MEDIUM GRAY
14 82510STKA01ZC COVER, L. RR. SEAT CUSHION (LOWER) NH690L: PREMIUM BLACK
15 82526STKA01 FRAME, L. RR. SEAT-BACK
16 82536STKA02ZB FRAME, L. RR. SEAT CUSHION NH556L: GRAY
16 82536STKA02ZD FRAME, L. RR. SEAT CUSHION NH690L: PREMIUM BLACK
17 82538STK000 PIPE, L. SUBMARINE
18 82620STKA02ZB LOCK ASSY., L. RR. SEAT NH556L: GRAY
18 82620STKA02ZC LOCK ASSY., L. RR. SEAT NH690L: PREMIUM BLACK
19 82690STKA01 BRACKET, SEAT PIVOT (OUTER) (L)
20 82691STKA01 BRACKET, SEAT PIVOT (INNER) (L)
21 82692STKA01ZB COVER, L. PIVOT (OUTER) NH557L: MEDIUM GRAY
21 82692STKA01ZC COVER, L. PIVOT (OUTER) NH690L: PREMIUM BLACK
22 82693STKA01ZB COVER, L. PIVOT (INNER) NH557L: MEDIUM GRAY
22 82693STKA01ZC COVER, L. PIVOT (INNER) NH690L: PREMIUM BLACK
23 82914STKA01 GARNISH, RR. SEAT-BACK BELT GUIDE
24 82915STKA01 COVER, RR. SEAT CENTER ELR
25 90105S3Y000 BOLT, FLANGE (8X22)
26 90131SH3003 BOLT, TORX (8X17)
27 90135S7AJ51 BOLT-WASHER (10X25)
28 934030802008 BOLT-WASHER (8X20)
29 938910501007 SCREW-WASHER (5X10)
30 9390125020 SCREW, TAPPING (5X8)
31 90300S84A00 NUT, SHOCK ABSORBER FLANGE (10MM)
32 82132STKA01 BUSH B, RR. CUSHION
