22 WATER PUMP
1 18011R70A00 VALVE SET, EGR
2 18715PB2000 GASKET, EGR VALVE (ISHINO GASKET)
3 19200R70A11 WATER PUMP (MAGNA POWERTRAIN)
4 19222R70A11 GASKET, WATER PUMP (MAGNA POWERTRAIN)
5 19301R8AA00 THERMOSTAT ASSY.
6 19305PR7A00 RUBBER, THERMOSTAT MOUNTING
7 19311R70A00 COVER, THERMOSTAT
8 19410R70L00 PASSAGE, WATER
9 19411P8AA03 GASKET, FR. WATER PASSAGE (NIPPON LEAKLESS)
10 19412P8AA02 GASKET, RR. WATER PASSAGE (NIPPON LEAKLESS)
11 19505R70A00 PIPE, CONNECTING
12 37870RTA005 SENSOR ASSY., WATER TEMPERATURE (DENSO)
13 91307RTA005 O-RING (DENSO)
14 91314PH7003 O-RING (31.2X4.1) (NOK)
15 92900080220B BOLT, STUD (8X22)
16 9405008080 NUT, FLANGE (8MM)
17 9430106100 PIN, DOWEL (6X10)
18 957010602208 BOLT, FLANGE (6X22)
19 957010602508 BOLT, FLANGE (6X25)
20 957010803508 BOLT, FLANGE (8X35)
