22 CYLINDER BLOCK - OIL PAN
1 11000RWC811 BLOCK ASSY., CYLINDER (DOT)
2 11103R40A01 PLATE, PARTITION
3 11106PNA300 BOLT, SEALING (20MM)
4 11106PR4013 BOLT, SEALING (28MM)
5 11135RAAA00 ORIFICE ASSY., BLOCK (LOWER)
6 11200RWCA00 PAN, OIL
7 11221RAAA00 PLATE A, BAFFLE
8 15152RWCA00 ORIFICE ASSY., OIL JET
9 15280R40A01 BODY, OIL JET
10 15290R40A01 BOLT, OIL JET
11 30530PPLA01 SENSOR, KNOCK
12 37241RNAA01 SWITCH ASSY., OIL PRESSURE
13 90001PM3003 BOLT, DRAIN PLUG (28MM)
14 90006PNA003 BOLT-WASHER (11X95)
15 90009PY3000 BOLT, DRAIN PLUG (14MM)
16 90401PR4000 WASHER, SEALING (28MM)
17 90705RWCA00 PIN, DOWEL (20X12)
18 90706RWCA00 PIN, DOWEL (16X9)
19 90715PC6000 PIN, DOWEL (13X20)
20 90715PNA000 PIN, DOWEL (13X14)
21 91214RZYA01 OIL SEAL (80X98X10) (ARAI)
22 91305RWCA00 O-RING (6.5X1.5)
23 91306PJ4000 O-RING (6.8X1.9)
24 92900060200B BOLT, STUD (6X20)
25 9410914000 WASHER, DRAIN PLUG (14MM)
26 957010601808 BOLT, FLANGE (6X18)
27 957010603008 BOLT, FLANGE (6X30)
28 957010603208 BOLT, FLANGE (6X32)
29 957010803508 BOLT, FLANGE (8X35)
30 957010805008 BOLT, FLANGE (8X50)
31 957011205508 BOLT, FLANGE (12X55)
