21 OIL PUMP
3 13432PNA000 SPROCKET, DRIVEN (17T)
4 13441RWCA01 CHAIN (62L)
5 13450RWCA02 TENSIONER, BALANCER SHAFT CHAIN
6 13460PNA004 GUIDE, BALANCER SHAFT CHAIN
7 15100RWCA03 PUMP ASSY., OIL
8 15115R40A01 METAL, BALANCER SHAFT (DAIDO)
9 15123RAC000 PIN, STRAIGHT
10 15124RAC000 PIN, STRAIGHT
11 15125RAC000 PIN, OIL PUMP DOWEL
12 15231RAC000 VALVE, OIL PUMP REGULATOR
13 15232RAC000 SPRING, OIL PUMP REGULATOR
14 15233RAC000 PLUG, OIL PUMP REGULATOR
15 15301RWCA01 BASE, OIL FILTER
16 15302RWCA01 GASKET, OIL FILTER BASE (A)
17 15303RWCA01 GASKET, OIL FILTER BASE (B)
18 15304RWCA01 PLATE, OIL FILTER BASE
19 15400PLMA01 FILTER, OIL (FILTECH TOYO ROKI) (SOLD IN MULTIPLES OF 30)
20 90004PNA000 BOLT, CHAIN GUIDE
21 90009PNA000 BOLT, FLANGE (8X55)
22 90015PH1013 HOLDER, OIL FILTER
23 90031PNA004 BOLT-WASHER (10X30)
24 9430110160 PIN, DOWEL (10X16)
25 957010601408 BOLT, FLANGE (6X14)
26 957010602008 BOLT, FLANGE (6X20)
27 957010602508 BOLT, FLANGE (6X25)
28 957010603000 BOLT, FLANGE (6X30)
29 957010604008 BOLT, FLANGE (6X40)
30 957010605508 BOLT, FLANGE (6X55)
31 957010606008 BOLT, FLANGE (6X60)
32 957010805508 BOLT, FLANGE (8X55)
33 957010807508 BOLT, FLANGE (8X75)
34 957011010509 BOLT, FLANGE (10X105)
