1 14535R70A00 PLATE, TIMING BELT STOPPER
2 15100R70A11 PUMP ASSY., OIL
3 15115R70A11 GASKET, OIL HOLE
4 15220RYEA01 STRAINER, OIL
5 15221RYEA01 O-RING
6 15231R70A11 VALVE, RELIEF
7 15232R70A11 SPRING, RELIEF VALVE
8 15233R70A11 BOLT, SEALING (18MM)
9 15301RN0A00 BASE, OIL FILTER
10 15302RDVJ00 GASKET, OIL FILTER BASE
11 15400PLMA02 FILTER, OIL (HONEYWELL)
12 37260RNAA01 SENSOR, OIL PRESSURE
13 90015PH1013 HOLDER, OIL FILTER
14 92900060161B BOLT, STUD (6X16)
15 90051P8AA00 BOLT, FLANGE (6X35) (SEAL)
16 91212R70A02 OIL SEAL (41X56X7) (NOK)
17 91319PAAA01 O-RING (13X1.5)
18 92900060181B BOLT, STUD (6X18)
19 9405006080 NUT, FLANGE (6MM)
20 9430106100 PIN, DOWEL (6X10)
21 957010602008 BOLT, FLANGE (6X20)
22 957010805008 BOLT, FLANGE (8X50)
23 957010807508 BOLT, FLANGE (8X75)
