19 A-C HOSES - PIPES
1 17713SE0003 CLAMP, FUEL PIPE
2 80050SJAH00 LABEL, AIR CONDITIONER CAUTION
3 80312STKA01 HOSE, SUCTION
4 80316S3N000 COLLAR, DISCHARGE HOSE
5 80320STKA01 PIPE ASSY., AIR CONDITIONER
6 80341STKA01 PIPE, RECEIVER
7 80361STKA00 STAY, AIR CONDITIONER PIPE
8 80362SNAA00 CLAMP A, SUCTION PIPE
9 80366SFA000 RUBBER, MOUNT
10 80366SFE000 CLAMP, DISCHARGE HOSE
11 80367SFA000 COLLAR, DISTANCE
12 80387SM4A01 CLIP, RECEIVER PIPE
13 80450S7S003 SENSOR ASSY., PRESSURE
13 80450SFE003 SENSOR ASSY., PRESSURE
14 80865ST0003 CAP H, VALVE (NICHIRIN)
15 80866ST0003 CAP, VALVE (L) (NICHIRIN)
16 80871ST7000 "O-RING (5/8"") "
17 80872ST7000 "O-RING (1/2"") "
18 80873ST7000 O-RING (8MM)
19 90105SFA003 BOLT-WASHER (6X30)
20 90106SMGE00 BOLT-WASHER (6X16)
21 90203SB0000 NUT, FLANGE (6MM)
22 934030601408 BOLT-WASHER (6X14)
23 935000400804 SCREW, PAN (4X8)
24 9405006080 NUT, FLANGE (6MM)
25 958010602508 BOLT, FLANGE (6X25)
26 80316STKA01 HOSE, DISCHARGE
