17 P.S. GEAR BOX
1 52362S30003 BOOT, TIE ROD END (MUSASHI)
2 53010STKA01 END SET, RACK
3 53434STKA01 BRACKET A, GEAR BOX
4 53434S84A01 CLIP, STEERING TIE ROD
5 53438STKA01 BRACKET B, GEAR BOX
6 53449SJK003 BAND, BELLOWS
7 53502STKA01 GROMMET, STEERING
9 53536SJK003 WASHER, TIE ROD LOCK
10 53537S3N003 RUBBER, STOPPER
11 53540STKA01 END, TIE ROD
12 53600STKA04RM P/S RACK, CORE ID (53600-STK-A04RM) (RMD) (RACK ENDS INCLUDED)
12 53601STKA04 RACK, POWER STEERING
13 53685SEPA01 BUSHING, GEAR BOX MOUNTING
14 53685STKA01 BUSH, GEAR BOX MOUNTING
15 53685STKA11 BUSH, GEAR BOX MOUNTING
16 53692STKA01 PLATE, POWER STEERING HEAT BAFFLE
17 90107STKA01 BOLT, GEAR BOX MOUNTING
18 90108STKA00 BOLT, GEAR BOX MOUNTING
19 90301SEP003 NUT, HEX. (14MM)
20 90506STKA00 WASHER, PLAIN (10MM)
21 934040601605 BOLT-WASHER (6X16)
22 9403012280 NUT, HEX. (12MM)
23 9420130220 PIN, SPLIT (3.0X22)
24 53429STKA01 DUST SEAL SET, TIE ROD
